Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Mine is a complaint, without question. I have a Samsung RF26X refrigerator that stopped de spencing water and also had water under the vegetable drawers, turning to ice. I started calling customer service within 6 months of buying this appliance. Once, an evaporater was replaced w/o charge. Another tech worked for 2 hrs then told me the gasket needed cleaning, an $85 charge.That was too goofy for me. A 3rd tech told me I need to buy my ice if I want to use the water dispenser. All my original complaints are still active. After 3 yrs, I called for a tech unrelated to the company Samsubg had been sending. This 4th tech said he would need to replace the circuit board along w/ something else for $500. My Samsung refrigerator has given me problems since 6 months of age, never successfully resolved, and Samsung insists we have to pay to get it working correctly. I HATE SAMSUNG!!
SOURCE: Low water flow from the water dispenser
Try to check the water really
Posted on Jan 12, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
  • 59 Answers
SOURCE: Samsung Refrigerator
This unit has a history of problems on the refrigerator side. the basic reset is press and hold down the 2 middle buttons on the freezer at the same time. As a general rule the number one problem is in the mother board. usually you can replace it and everything will work.
David
Posted on May 22, 2009
SOURCE: Samsung RS2556SH
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it? Please anwser me through my email: alicezhang90@yahoo.comThanks.
Posted on Jun 10, 2009
SOURCE: samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Posted on Jul 28, 2009
Ge profile refrigerator water under vegetable bins
Most likely defrost drain is clogged
Nov 13, 2017 | GE Refrigerators
Water is pooling in bottom of refrigerator and left vegetable drawer, need to empty it every three or four days.
im no expert but maybe the water line? That happened to a friend of mine and thats what it was
Mar 21, 2015 | Samsung Refrigerators
Water in vegetable drawer samsung RF217ABRS refrigerator
The vent at the rear is possibly blocked.
Jul 14, 2014 | Refrigerators
My Samsung refrigerator is leaking, what can I do?
Please check under the vegetable drawer, can you see a puddle of water?
Aug 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Have a Samsung RF217 Refrigerator that is collecting water in the right vegetable bin? Fridge does not have ice maker.
Just had mine repaired. The evaporator drain is plugged with ice. The solution is to replace the heat sensor and add a piece of metal extending from the small heat coil under the evaporator that supplements the piece already there. The guy that repaired mine used a piece of coat hanger wire for the extension. Except for the heat sensor, it's a repair anyone can do. Just take off the plastic cover on the inside back of the fridge, melt the ice obstruction in the drain and hang a piece of wire from the heat coil into the drain. He also used some metallic duct tape to raise the height of the drain tray on the ends so that it wouldn't overflow in the future.
Jul 01, 2012 | Samsung RF217ACBP
Water in the vegetable drawer samsung refridgerator
Thank you I have a rb 215 and having the same problems so yes this does help a lot... thank you t
Jan 22, 2012 | Samsung RF217ABWP (20 cu ft) Bottom...
The "water" light on the display panel went dim for a couple days and is now out. everything else seems to work ok. What's the problem? K
i have the same problem except mine is on a samsung RF26X side by side french door fridge and the cubed ice light went out. same as yours, the light was dim for 2 days and then went completely out. i've had the fridge since july 2010. did you get help with a solution?
Sep 20, 2010 | Samsung RM255LASH Side by Side...
GE TBF17PC top freezer water under vegetable
The drain hole is inside the freezer. you have to take the back panel off to get to it and thaw/clean it out. if this drain stops up it will cause water to run down the back wall of the refrigerator down to the bottom. you can pull the refrigerator out from the wall and see the plastic tube coming from the back of the freezer.
Jul 11, 2010 | GE Refrigerators
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
57 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
