Question about Canon Zoom Telephoto EF 80-200 f/4.5-5.6 II Autofocus Lens
Canon 80 200 4.5-5.6 lens
Autofocus lens but the switch is stuck on manual. How to fix?
  • 7 Answers
SOURCE: Canon digital camera will not focus
Check your diopter adjustment. It should be a small wheel on the upper right of the viewfinder. It is designed so that people who normally wear eyeglasses can use the viewfinder without their glasses, but it can occasionally get bumped. If the diopter adjustment is way off, it is like looking through someone else's eyeglasses!
Posted on Mar 18, 2008
  • 9 Answers
SOURCE: Autofocus has failed on the CAnon EOS 40D. I can
It's not the Autofocus, there's no 'non-engineer' fix. Lens and slider have failed, it's basically broken inside and I suspect it was the original fault. It's about £160-200 outside of warranty to fix via a canon authorised repair agent such as www.camera-repair.co.uk in Colchester. Send it back, get your money back.
Posted on Jul 07, 2009
LaSander
  • 14 Answers
SOURCE: Canon 40D Autofocus not working
Maybe The Button Is Broken Chek The Button If It Still does Not work Let an Axpert Chek Your camera
Posted on Sep 22, 2009
  • 12 Answers
SOURCE: Canon EOS 5D Autofocus will not work.
ho.....ho...
I have this prob in my canon EOS kiss SLR.
CHECK THAT>>>>>>>
Hold the camera vertically.Switch on the AF and let the camera to auto focus.!!!!!!!!!!!!!!!!
Don't wondering....Check ur camera's sub mirror in the in side of the sub mirror.The spring that push back sub mirror from the main mirror is broken.......!
How to repair this? Follow this link....
http://www.facebook.com/home.php?#/album.php?aid=2042115&id=1359757176
Posted on Nov 04, 2009
  • 12 Answers
SOURCE: my canon 18-55 IS lens cant autofocus
try clean the contacts you're self by using an eraser or cleaning pencil.
did u check the Exposure Meter is working correctly?????????
Check that now..........@ reply to my mail..
Posted on Nov 05, 2009
Testimonial: "Hi Seyapathum! I tried cleaning it. and also the body. But same thing happened. the meter is still working. coincidentally, the body's curtain"
Canon Rebel XSi won't autofocus and makes grinding sound
There is nothing that auto-focuses except the circuit in the body - all the motors, gears etc. are in the lenses. If this is a 18-55 lens then more than likely the long shaft gear has broken teeth - a very common problem.
Mar 30, 2013 | Canon Rebel Cameras
Autofocus problem on canon 135mm f2
If it focuses OK on manual focus and won't focus on auto focus the problem may be down to a broken ribbon cable in the lens.
May 06, 2017 | Canon EF 135mm f/2.0L USM Telephoto Lens...
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
Autofocus Failure - stopped working
Replace the broken ribbon cable in the lens
May 23, 2010 | Canon Zoom Wide Angle-Telephoto EF...
I can't get the autofocus to work on my new EF 75-300mm
I don't mean to insult your intelligence. You did check the Manual/ Autofocus switch on the side of the lens, yes? Maybe move it back and forth a couple times?
Is there a Macro switch on the lens? If so, adjust the lens-by hand- to where it lets you set the switch back to normal 75-300. You may have to zoom it out to 300 before you can slide that off Macro.
Try shutting down the camera and then back on ?
Remove lens and reinstall it?
Compare the electrical contacts on the lens to your other Canon lenses?
It could just be that one in 10,000 that is defective outa the box.
lightspiritphotography.com
Dec 25, 2009 | Canon 75-300mm f/4-5.6 III USM EF Lens
Autofocus has failed on the CAnon EOS 40D. I can power the camera up with lens in manual but as soon as I go to autofocus it becomes unresponsive. The viewfinder goes black. Swapped batteries and lenses....
Jun 30, 2009 | Canon EOS 40D Digital Camera
Canon Rebel Xti Wont autofocus
I dropped my camera and thought the autofocus broke. It turn out that it swithed from autofocus to manual focus. There's a switch on the lens. Check if that's your problem too.
Sep 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Autofocus is stuck on Quantaray 28-200mm F3.8-5.6
NEVER open it up. You will destroy the dust seals. Have Canon repair it.
Apr 15, 2017 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Canon Zoom Telephoto EF 80-200 f/4.5-5.6 II Autofocus Lens Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
