Question about Troy Bilt 175HP Manual 42" Riding Mower
Flooded carburetor nikki carburetor
    Top Expert:
  • Troy Master
  • 50,514 Answers
Remove the needle and seat assy and clean out material that stops the needle from doing the job. Check the condition of the needle and replace if necessary. Ensure seat is tight and the float level is adjusted properly.
Posted on Apr 28, 2013
Need vacuum hose diagram for Nissan 4.2l TB42 engine on Nikki carburetor 21J360-23
all you want is in service and repair manual with diagram and you can get the manual from the given link which will help you to fix the problem by your own http://toolsnyou.com/
May 09, 2018 | Nissan Cars & Trucks
Installed new Nikki carb. Engine runs as if too lean while spitting and governor pulsing. Air/fuel adj needle has no effect either fully seated or removed. Runs smoothly if choke is roughly 3/4.
Sounds like you have an air leak and all the air/gas going into the engine is not going thru the carb. Remove the carb and re-check everything. Hope this helps.
Here's a YouTube rebuild video.
Clean And Repair Nikki Carburetors on Intek Engines
Sep 13, 2017 | Craftsman Garden
Need assembly diagram for nikki Carb 79778
You will find a lot of pictures and diagrams
nikki Carb 79778 Google Search
Mar 31, 2016 | Garden
Nikki carberator 692475 flooding engine
needle and seat problem
replace and adjust the float level
Nov 30, 2015 | Cars & Trucks
LA110 only runs with choke
Most likely the Nikki carburetor needing a good ultrasonic cleaning and a carburetor repair installed. It would be best for regular lawnmower repair shop to do this as the Nikki can a pain to get the parts replaced correctly and even the new gaskets can leak sometimes.
Oct 21, 2013 | John Deere Garden
I need a diagram for a nikki 498888n carburetor. It goes on a B & S 14.5 h.p. It checks 50 psi pressure
You can get a breakdown of the carburetor on a parts website like partstree.com by entering the model number off the engine, and picking the appropriate type number, and selecting the carburetor and you will get an illustrated parts diagram which includes and exploded view of the carburetor.
I hope this helps you out.
Aug 23, 2011 | Garden
P have a Toro riding mower and found that when I drained the oil it appeared to have gas in it. Last season near the end of the year it would blow a black liquid out the exhaust when it started.
It seems the carburetor is flooding and overflowing into the crankcase. This is a common problem. Need to determine what type of carb. you have: Walbro or Nikki to suggest a fix. Some simply put an in-line shut off valve between the tank and the carb. and turn the fuel "off" when they are not using the mower. You will need to change the oil and oil filter (if you have one). Hope this helps.
Mar 20, 2011 | Toro Lawn Mower With Toro Power Tools
Its a briiggs and stratton 16.5 hp model #313777 0112-E1. I'm gettin gas in my oil and am pretty sure float is sunk and it won't start at the moment. The carb bowl spins clockwise and counterclockwise but...
You need to determine if you have a Nikki or Walbro carb. The Nikki bowl is held on by two phillips head screws and the Walbro bowl is secured by either a single bowl nut or a anti-backfire soleniod (two wires going to it). Your problem is probably the seat in the carburetor. We see very few float problems since most of them are plastic.
If you have a Walbro with the anti-backfire solenoid you will need to get a slim 1/2 open end wrenc the access the "flats" on the solenoid to unscrew it.
The brass seat is replaceable in the Walbro along with the needle. If it's a Nikki, you may need to replace the carburetor.
Hope this helps
Feb 14, 2011 | Garden
Nikki carbureter have installed new kit but still floods up and runs rough any suggestions
remove the float bowl cover and set the wet float level. There should have been instructions with the rebuild kit on how to do this. If you don't have experience with carburetors, ask an old mechanic to help.
Aug 22, 2010 | Toyota Pickup Cars & Trucks
Troy Bilt 175HP Manual 42" Riding Mower Logo
216 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
