Question about Honeywell Heat/Cool Thermostat
How to install honeywell thermostat T6373A1108 to wall mounted inverter type aircon.
SOURCE: rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Posted on Dec 29, 2008
tborn6
  • 700 Answers
SOURCE: Honeywell humidistat stuck
what i would do is make sure tha the hole for the wires that go to the humidistat is completely closed and that you are sensing the true humidity for the space also have the tech wire the so that the heat comes on instead of the ac for the de-hiumidification process.
Posted on Feb 22, 2009
  • 116 Answers
SOURCE: Updating old honeywell thermostat with a new honeywell thermostat
check in the unit heater to see what is hooked up most only need to have red from transformer white to call for heat and green to make the fan run in man and somtimes common usually blue or black
Posted on May 10, 2009
  • 674 Answers
SOURCE: I am having problem installing my new Honeywell
Go to the link I am providing and they show the connection for a 2 wire and a 4 wire hook up. If you have any questions, let me know.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1918EF.pdf
Posted on Jun 20, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: The wall mounted thermostat in a condominium unit
i think you may have a fan/control board problem, if the thermostat turns on the fan, and you dont touch it, then the fan stops in a short time...
plus the fan is connected to a control board, like i said those thermostats hardly go bad...
Posted on Dec 19, 2010
Why is our inverter very noisy?
have it inspected by a service person for correct operation
check that rubber insulators were installed under the mounts of the machine
check that the installation is in line with the manufacturers recommendations so to prevent vibrations in walls and surrounds
Nov 04, 2017 | Inverter Heating & Cooling
Replace a honeywell t822l1000 with a programmable unit
Match the thermostat wires to the letters on the new thermostat terminals R Red Y yellow ETC.
Nov 16, 2014 | Honeywell T827K1009 Mercury Free EconoStat...
Honeywell ac thermostat not working
The replacement batteries may be no good or may have been installed with the wrong polarity. Also, if your Honeywell thermostat latches into a wall mount, you may have reinstalled it incorrectly. I speak from experience
Jun 18, 2013 | Heating & Cooling
Honeywell t6373a1108
Not sure if your needing info on air conditioner or a thermostat but here is the link to honeywell. Just choose your product and model #. If it was the thermostat your replacing, look back at the old one and write down what wires went where. There should be letters/numbers by each connection. This will help with the new installation.
http://yourhome.honeywell.com/home/Applications/FindOwnersManual.aspx
Apr 27, 2013 | Honeywell Heating & Cooling
Wiring for Honeywell H46C1166 - Dehumidistat, 24/120/240 Vac Wall-Mounted
Suggest you people READ the question before giving BS answers !!!!!!!!!!
Jul 22, 2012 | Honeywell H46C1166 - Dehumidistat,...
The wall mounted thermostat in a condominium unit (central HVAC in a high rise) is defective. I need to know 1. how to take out the existing thermostat (Honeywell T6069A1008) and 2. what replacement is...
Dec 19, 2010 | Honeywell Heating & Cooling
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Th8000 does not match another thermometer inside home
Is the thermostat mounted near a lamp or other heat source?
Is the wall warm from ducts in the wall or a refrigerator on the other side?
The thermostats are usually pretty accurate. Most times I find some other influence on the thermostat causes the problem.
The Honeywell 8000 series also has a feature accessed through the installer setup menu, that will allow the temp display to be changed + or - 8 or 9 degrees.
Check the manual or Honeywell's website for a .pdf if you need it.
Hope this helps.
Matt
Jan 11, 2009 | Honeywell Electronic Programmable...
How do i uninstall my old honeywell mercury thermostat
There are three parts to a T87F thermostat. Outer ring, thermostat body, and base mount. Remove the snap on ring that goes around the dial. Remove three screws from the thermostat that mount it to its base. Remove the thermostat. Disconnect and record what screws each wire attaches to. Remove the screws holding the base to the wall.
Jul 12, 2008 | Honeywell Heating & Cooling
Honeywell Heat/Cool Thermostat Logo
247 people viewed this question
Top Honeywell Measuring Tools & Sensors Experts
Dan Webster
Dan Webster
Bill Long
richie46
Are you a Honeywell Measuring Tool and Sensor Expert? Answer questions, earn points and help others
