Panasonic dmr ex77 produces black and white digital broadcast
Black and white on Digital and Colour on Analog TV HELP!!!! URGENT!!!!!
SOURCE: Making my Panasonic DMR EX77 multi zone
i have the same player and wont play burned dvds
Posted on Sep 27, 2008
SOURCE: panasonic dvd recorder dmr-ex75
Change the AV settings on the DVD or TV to be the same format. Feeding AV into an AV-S gives B&W
  • 8 Answers
SOURCE: Overseas dvd playing in black & white instead of colour
Go into main menu on the DVD player, then (probably) the picture menu and find a setting that says either Pal or NTSC. Then change it to the opposite one. These are to do with the signal coming into the TV from the aerial. Just go through all the menus until you find it, or post on a forum specific to your player (and say what sort), so someone with the same one can help you navigate the menus.
It all depends where you are writing from and where you got the DVD player from. I know Pal is used in NZ and the UK, and NTSC is used in the USA. I don't know about other countries, these are the only ones I have experienced, through buying foreign DVDs. Your signal is obviously coming through in one format and your DVD player is set to the other (incompatible) one. Change the DVD player to match your TV and you'll be fine.
Posted on Jan 21, 2009
  • 5 Answers
SOURCE: Loss of TVGOS signal ...
Please contact Michale Finney of ABC news.com 7 on your side. If he hears form enough people He will get the transmissions fixed. copy and paste the URL below to reach him.
http://abclocal.go.com/kgo/feature?section=news/7_on_your_side&id=5814629
Posted on Oct 23, 2009
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Posted on Apr 18, 2010
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white.
programs recorded from tuner are now in black and white
Frank, try new cables and inputs if you can, cables or inputs could be faulty.
Apr 01, 2016 | Panasonic Televison & Video
NOT GETTING COLOUR FROM CCTV DVR TO TV BLACK WHITE
Missing information alert. What is meant by "to TV black and white"? Are you saying you can't get playback on a black and white (and therefore old, analog) TV set? What connection set up are you using between recorder and the playback TV? At first glance it would appear you might need a digital to analog converter to process the DVR output prior to feeding it as a SD (standard definition) signal into your TV set for mmonitoring. thanks for clarifiying your question, including a description of your setup.
Dec 23, 2012 | Home Security
How do you re-tune the panasonic DMR E85H DVD Recorder. I have done exactly as it says in the manual and still it does not find any channels? Is it digital?
The tuner in the DMR-58H is a NTSC tuner (analog). Unless you have a low power station in your area, you will need a digital-to-analog converter box to record OTA stations. It can record analog cable without a box as well. (Digital cable will require a box.)
The manual for the DMR-E85H is available from Panasonic here: http://service.us.panasonic.com/OPERMANPDF/DMRE85H.pdf .
I hope this helps.
(at least in my area there is only one station broadcasting an analog signal; it is a low-power transmitter and thus wasn't required to upgrade to digital with the rest of the stations.)
Mar 27, 2012 | Panasonic DMR-E85H DVD Recorder
Have a panasonic dvd recorder model number Dmr-Ex77. which worked fine now it records and only lets us watch in black and white. cant work out what to do change it back to colour.
Good day!!!!
I can help you for your problem in dvd players cause i am audio video technician for 5 years and manage my own repair shop..
If you wish to solve that problem please try to click this link
I can fix all brand of your DVD
and get my service..
Oct 20, 2011 | Televison & Video
Our tv doesn't have sound or picture
You need a Digital to Analog converter box as your TV is analog, and all broadcasts, since Last June 12 are Digital.
Apr 16, 2010 | Sylvania 6520FDE 20 in. TV/DVD Combo
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
No sound from my htr-6030 when i hook it up to my dvd player with
If you can't use one of the Optical Digital Audio INPUTs on the HTR-6030, why don't you just use the Analog Audio Out on the HDD and an Analog Audio IN on the HTR-6030? It has one actually marked 'DVR', but any one would do.
Mar 19, 2009 | Yamaha HTR-6030 Receiver
Panasonic dvd recorder dmr-ex75
Sep 16, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
How do I flash the firmware for a Panasonic DMR-EZ47V?
According to the Engineering channel schudle there is a new firmware (v.1.13)for the following panasonic models
DMR-EZ27, DMR-EZ47, DMR-EX77, DMR-EX87
This is scheduled to be broadcast on 6-2-08.
http://www.dtg.org.uk/retailer/download_schedule.pl user_offline.gif
Jan 31, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Switches randomly to black and white
this might help u have to go t the setting and set the NTSC-PAL to atuo or NTSC
Jan 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
