Question about Continental A/c Evaporator Core 65226010534
Replacement evaporator core 2007 dodge sprinter
2007 dodge sprinter belt and pulley diagram
There is a belt routing diagram under the hood.
May 18, 2016 | Dodge Cars & Trucks
2007 dodge sprinter engine code p2033
The first one sensor 1 is located just ahead of the converter. The second one sensor 2 (the one you are looking for) is located right after the converter.
Sep 26, 2012 | 2007 Dodge Sprinter
Need to change fan belt
Hi
Get a full repair manual for your Dodge Sprinter from the link below,
www.automotix.net/autorepair/diy/2007-dodge-sprinter_2500-procedure_sb.html
Feb 23, 2012 | 2007 Dodge Sprinter
Hi i have dodge sprinter 2007 and i can not move , my obd give me this messege P 0676 , so you can give me pls some advises. Thx
Thrie is no P0676 code However replace the Transmission Range Sensor. And the Shift Solenoid.This should get you mobile again. Good Luck.
Dec 10, 2010 | 2006 Dodge Sprinter
The key will not turn in my sprinter. it worked
try turning the steering wheel in one direction while turning the key. this may require some force. if it doesnt work then try turning it the other way
Jul 11, 2010 | 2007 Dodge Sprinter
Where is the fuel filters on the dodge sprinter 2007 diesel?
It is on top of the center of the engine, you will have to remove the air filter box to access it.
Jun 12, 2010 | 2007 Dodge Sprinter
My 2005 dodge sprinter drive fine for about five min.it lose power can,t go any faster but i can stop cut car off an restart it an you goagain for a while.
Its common problem on dodge sprinters, change your turbo resonator, its plastic, replace it with after market solid aluminium one.
Sep 13, 2009 | 2007 Dodge Sprinter
DODGE SPRINTER DIESEL
remove air cleaner...then remove the black engine cover....the filter is under it
Feb 10, 2009 | 2007 Dodge Sprinter
Oil change, 2007 sprinter
it is telling you which direction to turn it to tighten the cap
Jul 12, 2008 | 2007 Dodge Sprinter
Continental A/c Evaporator Core 65226010534 Logo
47 people viewed this question
Top Continental Heating & Cooling Experts
Tim Whalen
Fotis Papastamatiou
jasbo
jasbo
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
