Question about RCA VR5320R 1GB Voice Recorder Digital
Recorder no longer working. Will not show up in Windows either
I have had my recorder for about a month. I recorded some files on March 18 and on April 24 I went to listen to them, they played fine. I was able to get one file onto my computer. I decided to quit and listen to my files on recorder. The next day It showed a low battery message I changed the batteries and now it shows my recordings, but it will not play them and it will not allow me to record anything else. I push record the red light comes on and the timer comes on but it wont do anything. I hit stop and it says it recorded for 1 second. I cannot delete files either. And when I plug the device into my computer, nothing happens. Windows and Linux neither one recognize the device. I hit play, I hear a "popping" sound but nothing happens. I need to at least get these files off of the flash memory does anyone have any suggestions or ideas. Even if I take it apart can I still put the memory in a card reader or something? Thanks
whitesox
  • 64 Answers
SOURCE: Connections
I reccommend live service with me, but I can definitely help. Please mark this as solved and we will arrange a time to work setup out. The question should be marked as solved because the one ANSWERABLE question, about the DVD being recorded, is NO, unless it is a home movie. Not only is it illegal, but also VERY difficult to do. and your equip is not cabable. Thanks!
Posted on Jul 27, 2007
shivam4529
  • 150 Answers
SOURCE: NOT DELETING FILES FROM RECORDER
this is so simple sir because i have same problem connect to the computer and right click to your drive and format it
Posted on Nov 15, 2007
SOURCE: RP5022 digital recorder - file corrupted message
i have a deffical time trying to burn to cd
Posted on Jun 21, 2008
  • 34 Answers
SOURCE: direct tv hdbox & Plasma TV & DVD SSound system & DVD recorder
Need to make sure you have the red,white,and yellow rca connection cables ran from the samsung dvd player to the red,white,yellow input on the back of the dvd recorder. Once you do that make sure you put your dvd recorder on line 1 input. If you look closely on the back of your recorder it should say line 1 input. If your recorder isn't on that input you can put the recorder on line 1 input by using dvd recorder remote and pushing the input button. Make sure you don't push the tv input button the dvd recorder remote there should be a seperate input button or a way to toggle the inputs on the recorder. Once you verify all that turn on your tv and go to the input on your tv that you watch the dvd recorder on and you should see what your recording on the tv.
Posted on Nov 21, 2008
  • 89 Answers
SOURCE: I have a RCA VR5320R
Your best bet is to play the recordings through the headphone connector to a pc audio line-in connector and capture the audio using something like Audacity. Then output them using audacity to mp3 to play on your mp3 player.
These units are notorious for their failing USB feature.
Posted on Mar 15, 2011
Sound recorder
Please check all of the settings options under the Control Panel - Sound.
Mar 09, 2014 | Toshiba Computers & Internet
My PC can't recognize my Panasonic IC recorder RR-US500
Which operating system are you using? This recorder has known issues with windows vista and windows 7 as well as Mac OS.
If you're using one of the above windows operating systems, try right clicking on the installer (setup.exe) file, select "properties". When the properties windows opens, select the compatability tab, and choose windows XP SP3 from the drop down menu, as well as click the box next to "run this program as administrator". That should run the installer as though you are running windows XP, and it should work.
Jun 06, 2012 | Panasonic Audio Players & Recorders
I have a Bell Office 600d digital voice recorder and Windows 7. I want to copy the recordings onto my PC, but when i try and open one of the files it says that the shortcut has been removed or deleted (i...
Hi Alana,
There is in all liklihood nothing wrong with your digital voice recorder. It was never designed to work with Windows 7 (any version). Try loading the voice files onto a PC with any one of the following operating systems:
Windows VISTA; Windows XP (Professional or Home); Windows Me; Windows 2000 (Professional); Windows 98 (Second Edition). It should function quite normally and download, so that you re-use the memory on your recorder.
Apr 25, 2011 | Olympus W-10 Digital Voice Recorder
Downloadable drivers for VN4100pc handheld that works on 32 bit
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows 7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows 7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
Mar 10, 2010 | Olympus VN-4100PC Digital Voice Recorder
Olympus W_S 100 can't record/erase
the dat files were removed off the recorder. put them back on and it should work fine. also try to format the recorder through the menu and not the computer
Oct 12, 2008 | Olympus WS-100 Digital Voice Recorder
Won't Record
I would like the answer to my problem about every file say full i would like to be able to erase the files that i no long want. I would like to delete the ones i no longer wants on the recorder.
Aug 03, 2008 | Sony ICD-P320 Digital Voice Recorder
JNC usb 350 digital voice recorder
i have jnc usb-350;
i can not installing drive and software.
i can not capture data from voice recorder to computer.
Jul 27, 2008 | Audio Players & Recorders
My stiletto records for about 18 minutes then stops
Daylight savings time change a few months ago messed up the timer recording schedule - you must now fix it. Daylight savings time changes will always mess up this recorder. You must reset your recording schedule.
For more info on fixing, go to:
http://shop.sirius.com/edealinv/servlet/ExecMacro?nurl=control/StoreItem.vm&ctl_nbr=2640&siId=1745656&catParentID=7874&scId=7874&oldParentID=&cid=SL100PK1
2 other remote possibilities:
If no signal is present at the time the recording is scheduled to start, the recording will be skipped.
Make sure you have followed all instructions on pp. 55-58
-Tha Mp3 Doctor
Jun 03, 2008 | Sirius STILETTO 100 MP3 Player
RCA VR5320R 1GB Voice Recorder Digital Logo
19 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
