Question about Garden
Homelite linetrimmer HLT26CDNB IGNITION COIL
NO SPARK. WHERE TO GET SPARES NEAR aUCKLAND
    Top Expert:
  • Garden Master
  • 42,818 Answers
Go to a small engine repair shop near you and see if they can get what you want. They may already have it in stock
Posted on Apr 28, 2013
Homelite chainsaw ut 10516 won't start have replaced all electrical parts still no spark why?
Incorrect gap on ignition coil? On/off switch stuck in closed position and grounding out spark?
Mar 30, 2017 | Homelite Garden
Homelite Lawn trimmer HLT26CDNB hard to pull start cord. Seems to be pulling against compression.
Take the spark plug out and see if it still hard to pull, if not it might have been the cylinder was flooded.
Mar 17, 2015 | Homelite Garden
I have a broken spark plug wire. Can these be replaced?
Steve:
Yes, the spark plug wire can be replaced, but you have to buy the ignition coil as the spark plug wire is hard wired into the ignition coil.
If the metal spark plug connector has disconnected from the spark plug wire, the connector can be replaced, but if the spark plug wire has been cut you'll need to replace the ignition coil.
Nov 29, 2013 | Homelite 200 mph 400 CFM Gas Blower...
My Homelite chainsaw is hard to start and stops running after 5 to 10 seconds.
Could be the filter in the tank or the cap. The tank needs to be vented to allow fuel past the filter.
Jul 03, 2012 | Homelite Garden
I have Homelite trimmer/edger for 3 years. It has been working great until recently, after a cold start and edging for 7 - 8 minutes it stops all of sudden until it gets cold and runs for 6 -7...
You need to check the ignition coil, by running until it quits and then remove the spark plug, reattach the plug wire and then ground the plug threads to the block and then try to start it. If you get no spark or very weak spark, the coil is bad and needs to be replaced.
I hope this helps get you going again.
Aug 17, 2011 | Homelite Mighty Lite Lawn Trimmer
No spark at the spark plug
Try this, if no spark replace the spark plug first(<$5) and retry.
It checks every part of the ignition system.
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when the flywheel is rotated.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 17, 2010 | Homelite ZR10926 16" Chain Saw
No spark superxl ut-10045-c
The following are givens:
1. You replaced the spark plug with a known good one and the malfunction persisted.
2. You did something similar to the following in an attempt to isolate defective parts and you concluded the ignition is not producing spark.
I found your saw "SXLO Chain Saw UT-10045-C" by following the instructions here:
Both the solid state ignition and condenser (most likely failures, but no promises) are NLA at the authorized site, part numbers are still valid. An Internet search for "Homelite YourPartNumber" displays many sources other than eBay.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 03, 2010 | Homelite Garden
Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
Oct 27, 2009 | Remington Electric Chain Saw
Have Homelite 33cc gas 14'' chain saw won't start. Getting fuel, but no spark. Was told coil is bad but chain saw is brand new. How do I test the coil?
hello sir please check the ignition cable connected to the sparking plug as you start the machine current should pass through the ignition cable and makes the machin to run.
Sep 25, 2009 | Garden
Homelite ut08107 will not fire. no spark at plug.
It may be the coil if there is not any spark. Or a wire could off at the coil. One more thing it could be is the spark plug wire may have came loose from the coil. These a few thing to check.
May 04, 2009 | Garden
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
