Question about Lenovo IdeaPad U510 Laptop Computer - 49412PU - Graphite Gray
Give me keyboard settings to on and off its button lights?
How we can on and off keyboard lights?
Press the Fan key and the space bar together...
Posted on May 30, 2013
Kensington keyboard manual
Your model number isn't listed, but all published Kensington keyboard manuals are available at
http://www.kensington.com/manuals
My keyboard (model K39336) connected easily, so here's what I had to do. Ensure the Ipad Bluetooth is on in settings. Turn on the keyboard, and when you see a single blue light, press the connect button. The iPad will give you a four digit code to type in on the keyboard. When you type in this code, the iPad and keyboard become 'paired' and keyboard input is available whenever the keyboard is turned on.
Aug 18, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
Just got the bluetooth keyboard and mouse w/ no manual. how do i set it up?m/s bluetooth keyboard WBR0295 X08-92475 product ID 69418-545-205333 5-00321 and m/s bluetooth mouse p/n X08 - 87659...
Hi.
Before starting, make sure the keyboard and mouse are ON and with batteries.
Whit the PC already ON:
* The first step is to plug in the USB Bluetooth adaptor.
* Once the Bluetooth adaptor is inserted, allow Windows to install the drivers.
* Once Windows gives it the OK, the USB dongle should have a light or even a button. (If you don’t see a button the "yellow" light is the button).
* Press the USB dongle button....this will tell the dongle to start looking for a Keyboard or mouse.
* On the underside of the mouse (and keyboard) should be a a small button.
* Press the button(s) for ~5 seconds, then release.. this tells teh keyboard (or mouse) to look for a dongle.
This should show a connection between the dongle and the keyboard (or mouse).
Or
With the PC Off:
* Just connect the dongle
* Do the button sequence as described above, unit the dongle light goes “solid” again.
* Start the PC and keyboard and mouse should work perfectly.
Cheers,
Ed
Oct 24, 2009 | Microsoft Windows XP Professional
No movement, no lights on usb portion
Check bios setting
Check your usb port
Re - install Usb 2.0 Driver
Aug 17, 2009 | Microsoft Comfort Optical Mouse 3000...
Keyboard and mouse not working
Make sure you have fresh batteries...usually this is how to set up a wireless keyboard and mouse. Insert the reciever in the USB and hit the link button normally located as a recessed button on the bottom, a light will blink....On the keyboard press the button as before located as a recessed button on the bottom. Once linked the reciever light should stop blinking...do the same with the mouse.
Jul 13, 2009 | Micro Innovations Wireless...
@ and " keys reversed
Go to "Control Panel>Local settings and language settings" , select the second tab "Languages" select the "Details...." button,
and change the US keyboard type to UK type or vice versa, whatever applies.
Jul 12, 2009 | Acer NSK8458AN Keyboard
Manual
Microsoft does not have manuals for their wireless keboards and mouse.
I will give you a few things to look at as I have the same Keyboard.
Normal 0 Go to Control Panel.
1. Click on Keyboard.
2. When the Keyboard Properties come up, CLICK on Key Settings.
3. Then set up the keys by selecting the Key to be changed.
Normal 0 Go to Control Panel and click on the Mouse icon.
Then select the Mouse button you need to program.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jul 29, 2008 | Computers & Internet
I have purchased a Microsoft Wireless Optical Desktop 700 (Keyboard & mouse). I have plugged the wireless receiver in, and get a flashing green light when I press the button on the front. The green...
When you say you pressed the connect buttons on both the keyboard and mouse, do you mean you pressed the connect button on the receiver, and then you pressed the connect buttons on the mouse and keyboard? If not, then that's what you have to do. The 30 seconds of blinking on the receiver is normal, as it gives you time to find and press the buttons on the mouse and keyboard.
I hope this helps, and good luck!
Jul 16, 2008 | Computers & Internet
Keyboard letters all mixed up???
Go to the control panel and open Regional and Language options. Make sure it's set for your country. Then click the languages tab and then details, make sure it's your language in the box.
Nov 09, 2007 | Fujitsu Siemens FKB 8720 Keyboard
Lenovo IdeaPad U510 Laptop Computer - 49412PU - Graphite Gray Logo
159 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
