Clark Forklift ECS20 throwing error code 24
I have a Clark Forklift that is giving me an error 24. It turns on, the forks move up and down, but when I try to go forward or in reverse it doesn't move. Just gives me the error code. It worked before we washed the entire machine. Any ideas?
SOURCE: LE error code
I have this washer and the LE error code generally comes on when there is hair and lint (and maybe a hairpin or coins) in the lint trap in the little lint trap on left bottom corner. Take a standard screw driver or quarter and pop open the hatch door. Pull the small black drain hose off the hook and drain into a pan or larger bowl after pulling little plug out of hose. Don't pullbefore you have something to drain it in, all the water will go all over your floor. Then there is a white basket that you unscrew and pull out whatever is caught in the trap. I have two girls with VERY long hair and three dogs. Usually this machine will give me the LE error after I have washed dog bed covers about every other time. It doesn't happen often, but it usually is hair balls basically. Otherwise no problems and love the machine.
Posted on Mar 13, 2008
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
SOURCE: LG-Trom Getting error CL .now not able to operate.after switch on it gives CL in display
Hai Idiots
ITs on CL (Child lock)
This occurs only if the power is turned off during the washing period
Press the TEMP and OPTION together for 3 seconds and it will go off
Amber
Posted on Nov 11, 2008
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
I have a clark dpm20n forklift that wont go forward or backwards. Can anyone give any advice? Thanks
clark forklifts have a safety device on the brake pedal hydraulics that prevents movement when lifting the forks
check the operation of that safety device as it may be jammed in the neutral position
Mar 14, 2016 | Clark Electrical Supplies
Wireing on a clark fork lift
I havent done of these for many a year but their is or was only a few wires for a forklift when i used to repair them ,both diesel and gas types so what exactly is the problem here that you need help with the wiring ?
Mar 07, 2012 | Welding Tools
Clark forklift hydraulic problems
Leaking valve on return line for tilt cylinder, or dirt.debris is keeping the sequencer valve open. The cylinder should be flushed to dislodge any nore. If the cylinder is showing an external leak, it was overloaded at the fork tips, and a seal or the stack ruptured. The valve and lines should also be flushed.
Jan 24, 2012 | Welding Tools
Tm 20 clark forklift error code -46 what does it
sounds like the #1 rectifier is shorted or the insulator gasket is shorted through -also the 1A contactor may be welded shut -usually caused by a weak battery or running a discharged battery too long. -Troy from A-Lift Services
Jun 21, 2010 | Clark Forklift Horn Button Switch , Cat...
Problem with Clark forklift TMX12-25 TMX250, red spanner warning lights come up. whats that mean, how to reset it
It means it's time for your periodic maintenance, the reset button should be close to hour meter
Feb 01, 2010 | Clark Forklift Horn Button Switch , Cat...
Why does my clark forklift lower by it self
it has bypass in the cylinders you need to rebuild it[put new seals in it].
Dec 21, 2009 | Clark Forklift Horn Button Switch , Cat...
Clark Forklift GPX25 will not shift into reverse. Unit was working fine a month ago. Do not use the forklift that often about once or twice a month. Unit will work in forward, but not reverse. Even when...
I got the same problem and same model, what's going on with Clark forklift, I look for the new transmission all over internet but can't find any. if any body know what wrong please tell us what to do. thanks a lot. TMV
Oct 03, 2009 | Clark Forklift Horn Button Switch , Cat...
Forklift hydraulic connections on the mast.
So if you have three cylinders then the extend ports of the cylinders(bottom) should go to the 'A side of the valve and the Rod end or retract (top) should go to the "b" side. The A or B are probably not marked. Each cylinder should go to the valve at the coresponding lever.
Apr 08, 2009 | Clark Forklift Horn Button Switch , Cat...
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
