Question about Philips 32PT6441/37 32" TV
Tv will not turn on after lightning storm
My Uncle's tv will not turn on after a lightning storm had passed by a couple of days ago. I believe its the power fuse but when I took it out, it does not look burnt or fried. Is there anything else that oculd be wrong or am I lookin in the right place?
Check IC location 7532, Diode locations: 6536, 6562 IET, Inc.
Posted on Aug 28, 2007
SOURCE:
Sony Bravia KDL series 52"
Check the fuses on the power board. there is one fuse on primary side and one on secondary side.
Take of back panel and follow plug into the tv.where it ends is the power board.always use caution.the capacitors in there hold high voltage even after unplugged for a couple of days.Discharge capacitors before servicing the board.
Jun 28, 2011 | Sony Televison & Video
Tv does not turn on after the storm
It is most likely the power supply burnt out. The capacitor's inside are made cheaper than the o'l days and get overheated easily. You can test capacitors with capacitor tester and service manual. You can test power supply output voltage with just a voltmeter
Sep 10, 2009 | Televison & Video
Lightning Surge, RCA 32V432T, will not power up
Throw TV AWAY,these tvs had alot of problems without lighting hitting them,It probably played out FBT flyback transfomer CK hori out put Transistor if shorted replace FBT also.
Aug 06, 2009 | RCA D52W19 52" Rear Projection Television
Turned tv off and now will not come back on,no sounds and no picture the fan also does not work
There is a small fuse in the board beside or close to where your power cord goes into your tv. Pull the fuse to see if it needs replaced. It will only cost a couple of books. Mine did this after a lightning storm.
May 14, 2009 | RCA HD52W58 52" TV
Blows fuses repeatedly on IWT3206 model
when electrical storm was going on the t.v. was on ? if it is was then return electrical / heavy lightning it may burn the parts.shorting through your mains and anteena conections, please clarify
Jun 24, 2008 | Televison & Video
Someone please help
Good Day;
Two things normally happens after a L storm:1.) One must unplug TV for 5 minutes, then plug back in. 2.) Main glass fuse out, will be near a/c cord. 3.( Power regulator IC may be out. Try these first.
Good Luck!
Jun 13, 2008 | Panasonic PT-52LCX66 Projection Television
Defective HV transformer. (Likely lost it during the storm)...accordianman
Nov 28, 2007 | Orion TVDVD092 9 in. TV/DVD Combo
Philips 32PT6441/37 32" TV Logo
296 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
