SOURCE: 2001 vw polo
Dear Customer,
check your sensors 1st,all sensors must be good
if all sensors are working good than check your engine firing sequence,some times happens when sequence was wrong,
check your exhaust and carborator tuning pin that creates the batter combination for firing in bore for batter performance & less emitions ,so check is it ok or not than go to your nearest service center that havad certified mechanics,
till you read this you had solve this problem definatly,
THNX
SOURCE: 2001 VW Beetle will not start
does the car turn over or does nothing happen at all? more info will help
SOURCE: 06 vw sharan 1.9tdi exhaust warning light on
can you tell me the resistances in ohms of the EGR valve
SOURCE: White smoke coming from AC and under hoods smells of burning oil
U HAVE A HEATER CORE LEAK, DOES THE SMOKE SMELL SICKY SWEET? AS FAR AS THE CEL GOES HAVE THE SYSTEM TESTED FOR FREE BY ANY KRAGEN AUTO OR AUTOZONE, JUST ASK FOR A OBD 2 TROUBLE CODE TEST, THEN POST THE CODE BACK HERE FOR US TO LOOK AT AND TRY AND DEVELOPE A FIX STRATEGY.
SOURCE: 2003 VW Passat "Oil Press, Turn Off Engine" and "STOP" Light
I would check the oil pressure sensor and the oil pump itself. You can take the sensor out and use a mechanical gauge to check the oil pressure. If the oil pressure is within specs, you need a new sensor, if not, you need a new pump.
