Question about Garden
John deere lt155
I took the deck off now I can't get the blade engage and disengage rod to work properly.When I engage the blades the arm drops down. And the arm must be pulled down to get the mower to start. Can someone help?
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
nova2nv
  • 197 Answers
SOURCE: my john deere lt 133 mower with a double blade
This model mulching deck uses a flat/ribbed serpentine belt that is set at very high tension.When belt breaks under the cover only one blade will turn due to IT being driven from PTO clutch as the other blade being turned from serpentine belt.This deck was Deere's first and last shot at making a true mulching deck and only made it a couple years.When you buy the VERY expensive belt it will come with detailed instructions on how to install it.Goog luck.
Posted on Nov 14, 2009
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
My john Deere sx95 blades not engaging plz help
When the blades on my John Deere fail to engage, I climb off the seat and look to see if the belt is still on. Belts get thrown, especially if you have too much grass on top of your deck. They also get stretched too much. I took a permanent marker and drew a picture of the direction of the belt around all of the pulleys. (Most mowers have this somewhere like on the deck or under the hood but I did my own).
Apr 09, 2015 | John Deere Garden
Why does one blade spin after mower is stopped on my John Deere LA135?
check your blade brake for that blade,supposed to rub against top blade pulley when blades are disengaged,if its a manual engage vs electric clutch
Jul 30, 2014 | John Deere Garden
The left blade on my John Deere LT155 stopped working
Besides the drive belt, there is a timing belt inside the mowing deck. The left blade is run by the timing belt. I imagine the timing belt is broken.
Apr 27, 2012 | John Deere Garden
John deere stx 38 with black deck, will not do anything, tested with ohm meter, get 12.83 volts from battery , get 12 volt to solenoid when turn key on, can start if i jump battery to solenoid, but mower...
I see this problem not as an electrical but a seize problem. Since I can't be there to inspect I am relying on your discription of the problem. I would go first to the place of the problem. If this solenoid goes up to disengage and down to engage ,or the opposite, this is most likely your problem area. It may be seized in the disengaged position therefore not allowing the blades to get spinning. Disconnect the belt and try to turn unit by hand, if tight or completely stuck use penetrating oil on pulley shaft.If shaft loosens up and blades engage this was the problem. Is there a grease fitting anywhere in the area?I hope this at least gets you started in the right direction. GOOD LUCK.
Jun 17, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
Why isn't the center blade on a john deere LX178
Of course with everything off, reach under the deck and turn the center blade by hand. If:
1. the blade turns by itself and nothing else moves, you need to tighten the retaining bolt more.
2. the blade, retaining bolt and drive shaft turn, check to see if the pulley above it is turning.
a. If the pulley turns freely check that the drive belt is going around it to power the blade.
b. If the blade turns with the drive shaft and the pulley doesn't, check that the pulley is still properly connected to the blade shaft. Some have a key in them that can split, others just have a bolt on top holding them tightly on the shaft.
Jun 16, 2011 | John Deere Garden
I have a john deere lawn tractor, 125. i broke the cable that engages the blades, i bought a new one, but cant see where the spring hooks up, above the deck?
Above the deck and from left side you go across deck the the idler arm that has the flat side of belt going around pulley. About halfway across arm there is a small hole that spring hooks to.
Jun 13, 2011 | Rc2 116 John Deere 125 Lawn Tractor
Blade on John Deere L110 will not shut off
Check the cable that runs from the acuating lever to the tensioner pulley on your deck it could be broken or frayed. also check the plastic holder on the deck end of the pulley, it fits in a small groove in a brace on the deck and is held in place by a tractor pin. when they removed your deck to sharpen the blades they may not have re-connected it properly or the plastic holder may be broken and not allowing the proper tension on the cable. if your tractor is equipped with a PTO switch near the lever check the connections and the continuity of the switch...hope this helps.... ;-D
Aug 10, 2009 | John Deere Garden
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
