Question about Vizio 55 1080P LED SMART 3D
Cracked 55 inch Vizio 3D Tv Screen How can I fix inexpensively? Thanks
Model #M3D550KDE
SOURCE: Vertical Red Line
I had a bright red 1" wide vertical line on the right side of my Vizio P42HDE as well as an equivalent Green line on the left. Sometimes a Blue line would appear adjacent to the red line. Had this TV sinc Oct. 2005. Based on internet research, I opted to purchase an LG 6871QCH060Q board (upgrade to the 6871QCH038A and the 6871QCH038C). Picked the board up on Ebay for $100 + $10 shipping from ShopJimmy parts.
From start to finish, this took about 2 hours to repair. Tons of screws to remove. Took me a while to figure out that the video connection unit in the back is completely modular and needs to be removed before attempting to remove the back cover. Once the cover was removed, I was surprised that I could not see where the replacement board was located. Turns out, you have to go one level deeper and remove the audio board and digital board followed by metal bracket/cover. Once removing the metal cover, the bad 6871QCH038A board was visible. A couple of zip ties will need to be cut as well as several cable connections to get to the 6871QCH038A board. Replaced the board with the 6871QCH060Q upgrade. Make sure to keep the sticky foam rubber isolation pieces and adhere them to the new board. It did take some time to figure out how to disconnect and reconnect all the various types of cable connections. Just take your time. The power cable connector for the 6871QCH060Q board is in a different location, thus I had to reroute the cable. Reassembled and only had 2 unused screws left!
TV workd great. Lines are gone. Have a little burn-in going on where the red line appeared, but still better than forking over $800 for a new 42" LCD 1080P TV. Hope to get a couple of more years out of this Vizio.
One line I found has a general example of LG/Vizio repair manual. Not exact, but close enough...http://www.scribd.com/doc/7580885/LG-TV-Plasma-Training-Manual
Posted on Feb 18, 2009
  • 59 Answers
SOURCE: Cracked LCD Screen
check ebay online for parts. the problem with a cracked screen is that to get it new, it cost too much. sometimes i find tv's that don't work but have good screens on ebay and you can pick them up cheap. good luck.
david
Posted on May 25, 2009
  • 4 Answers
SOURCE: 37 inch vizio has black screen. the vizio display
L37HDTV10A THE TV ON NO VIDEO NO MENU SAON OKEY
Posted on Jan 21, 2010
  • 8457 Answers
SOURCE: We had one of our kids accidently have a WII
No,Sorry it a junk tv now.Only use for electronics componnents parts.LCD Screen very tightly control by the TVS industries.Buy a new LCD Screen will cost same as a new tv after part and labors.
Posted on Feb 21, 2010
  • 473 Answers
SOURCE: my 46 inch vizio tv has a pale white screen with
Issue with your White balance Chipset Check for Diode and Capacitor leakage
Posted on Sep 22, 2010
Where can I purchase a t-con board for my 3D 55 inch vizio tv
Ebay has parts but there are other sites on the web that do also. Important thing is to have the exact part number. And make sure that a replacement part is exactly the same. If not, it is not uncommon for replacement to not work properly.
Mar 10, 2016 | Vizio XVT3D554SV 55 Full Array LED Full HD...
How to fix a damage screen for a vizio vf550m
Vizio Flat Screen Repair - All - Instructables
www.instructables.com/id/Vizio-Flat-Screen-Repair/
InstructablesWhere can I get a replacement screen for a Vizio 70" that cracked. Model .... Is there a repair to resolve this problem and where do I find information? IMadeIt
Vizio TV cracked how to fix this? - YouTube
? 0:22
https://www.youtube.com/watch?v=d3wSCSfatjQ
Jan 27, 2014 - Uploaded by mario gutierrez
Find out how to repair this? I have the ... Cracked TV Screen - LCD & LED TV Panel Repair Options & Replacement ... VizioFlat Screen Repair.
Dec 10, 2015 | Vizio VF550M 55 in. LCD HDTV
I have a 55 Vizio 3D smart tv. This picture color fade in and out to the point that I cannot watch tv. I this a problem with the main board?
Hello Patricia,
  • There is a loose soldering connection in the Main Board. That happens because the components on the are generating a lot of heat therefore melting solder connections.
  • Stop beating on the TV's back, that only makes the problem worse.
  • Take it to a shop.Or if you are a tech, try locating the loose connection(s) and solder it back.
  • Also check your Warranty Period, It may cost you 0$. Call Vizio if you still have Warranty on the TV.
Here is a link to Vzio Supoport.
Good Luck,
JP
VIZIO Product Support and Services VIZIO
Jun 25, 2015 | Vizio M3D550KD 55 inch Class Razor LED...
Samsung 55" cracked screen
No repair to a cracked screen; other than replacement.
Feb 02, 2015 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
Vizio 3d 55 m3d550kde controls and remote wont work
Check its standby voltage 9V & 3.9V supply rails. If any of it is lost, the TV's main system control section won't go. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 23, 2014 | Televison & Video
Cracked screen vizio e3d420vx
If set cost 1,000 new Panel will cost (just the part) 1500.
May 01, 2012 | Vizio XVT3D424SV 42 in. 3D LCD TV
I want to purchase the replacement LCD screen (just the part) for a 55 inch LCD vivio VF550M. My grandson cracked it with the Wii remote while bowling because he was not wearing the wrist strap. Looking...
Not going to happen. Those screens are the most expensive part of a TV as well as the most fragile. It would never survive shipping without the hard bezel around it. Sorry to say you are going to most likely be shopping for a new TV.
If anyone will sell just the panel, it would be Vizio, but they will most likely require you to ship them the TV which will cost more money and may not be covered by your warranty.
Seriously, often the cost of replacing the screen is high enough to just spend the money buying a new TV.
May 14, 2011 | Vizio VF550M 55 in. LCD HDTV
I need a new panel screen for my 55 inch vizio model number vf550m. The part number is lc550wudSBA1 I believe. how much am i lookin at for buying that? i cant find anywhere online that sells them. my...
Sorry u out luck,no where u will able to buy the LCD screen panel,the only place u can buy a LCD screen panel is at the Vizio tv Corporation itself.The tv LCD screen panel are limited in production.They'll sell it to u,but they'll charge u the same as a new tv.Tries trade the tv it in with the Vizio tv Corporation,u can get like 10% or 20% off toward a new tv.That all u could do.Or u only can sell the tv that have a crack sreen panel tv for it electronic boards for parts that it to get some money toward ur next new LCD tv purcharse.
Nov 14, 2010 | Televison & Video
Vizio 55 1080P LED SMART 3D Logo
24 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
