Question about Xtreme Sound WMS303 CD Player
No power I was installing a cd player. before i fully mounted the player i plugged all wires in and tested to see if it worked. it worked , but after i got everything installed I had no power.checked all fuses and tryed installing the stock radio back in and no power to that either??? anybody have an idea??
  • 156 Answers
My guess is that when you pushed the player into the dash, you pinched a power wire, resulting in a blown fuse. Check the vehicle's fuse box. Most vehicles have at least two fuses that provide power to the radio, though they may not all be labeled as radio fuses. You may need to check all the fuses in the vehicle, including any fuse box under the hood.
Posted on Aug 07, 2007
SOURCE:
How to wire cd player up in 2000 chevrolet malibu
I just discovered there are wiring harness adapters as I used one on my car to install a new cd player recently. I found this one on the internet not sure if it is the same car you have.
http://www.installer.com/item/display_item.php?it=71-1858
then you can buy a harness adapter from this adapter to the make of cd player like as an example Kenwood Cd player adapter.
A car auto store may know about these wiring harness adapters the advantage of using them is it makes it easy to install the cd player and if you ever decide to change the cd player in the future you can buy the adapter suited to the future player and plug it into the malibu car wiring adapter as the car adapter converts the factory wiring into a universal wiring standard.
A tip
make sure the radio and cd player works and the climate control work properly before completely re assembling the dash board .
I forgot the aerial cable plug !
I used Aeropro brand of wiring harness for my car that I got from
Car Accessory store in my country . I had to cut one wire and connect it to Pontrol to get my power aerial to work correctly. Which the store salesman helped me work out which wire controlled the cars power aerial
Sep 17, 2015 | Chevrolet Cars & Trucks
Radio will not go off
Hi Steve, I'm glad to help! I'm assuming you installed the CD Player and now it stays on. Most CD Players have 2 power wires, sometimes only 1. If your only has one then you have your power wire connected to a wire on the vehicle that stays hot with the key in the off position. Here's what you do to find the wire you need. Take a test light and place it on a fuse in the fuse block, then turn the key off and if the test light turns off thats where you want to connect the power wire for the CD Player. Then when you turn the key off the CD Player will go off also. Hope this helps and have an awesome day Steve.
Mar 09, 2014 | 2005 Dodge Magnum
Cd player INOP. Fuses check normal. all other electronics ok
this could be your CD player itself, or the power getting to it. If you have installed the player after-market, then there is a possibility that the power cord has come unplugged, or a wire splice on the wiring harness has disconnected ... check the player itself, and the wiring harness that it attaches to. There is also a small fuse on the CD player itself (usually on the back of the player near the power cord)... if this has blown out, replacing it should fix the problem. If it is plugged in, and the fuses are fine on the car's fuse box and on the CD player itself, the you might have a short in the wiring between the fuse box and the player's wiring harness. If this is the case, you can run a bypass to the CD player's power, or you can take it to a professional to have the problem diagnosed. If you are not experienced with installing car audio components, I recommend the professional assistance -- with the car in front of them, they can run more tests and tell you if it is the CD player or something else.
May 26, 2011 | 2002 Lincoln Navigator
I need to know how to install a cd player in my 1997 jeep wrangler sport.
My suggestion would be to buy a wiring harness and a dash mounting kit. After that unscrew or pull out the console/dash part thats around your factory deck. Then unscrew the bolts/screws holding the factory one in place. Remove it. Plug the wiring harness into the factory wire plug. Pull harness wires through the mounting kit. Attach the corresponding colored wires from the harness to your new deck. Slide your deck into the mounting kit and secure it in place. Most decks have little prongs that you can pry up to **** up against the mounting kit so it wont slide out without pushing those down (makes it more secure and harder to steal). Place deck with mounting kit into area factory deck was. Put the screws/bolts back into place tightly. Place console/dash part back on. You will need the mounting kit (99% of new decks are smaller than the factory). Wiring harness is optional but recommended.
Jun 22, 2010 | Panasonic CQ-C7105U CD Player
How do I know if a new/used car cd player will fit?
yes.......... just buy a mounting kit for your car and a wire harness for your car.........to install just unplug factory radio and clip the harness on to factory plugs that you just unhooked from factory radio now just attach the same colour to colour wires from your new deck to the harness......mounting kit comes with instructions
(make sure to buy WIRE HARNESS & MOUNTING KIT for your car) and your install should take less than a hr to do
have fun
Feb 18, 2009 | Pioneer DEH-P2000 CD Player
Problems with car audio
you should plug in the new harness and meter the wires to make sure there is power on two of the wires one will always be powered for memory the other should be powered when ignition is on if both test ok then check the in line fuse links on the radio wire harness I hope this helps good luck....
Jan 10, 2009 | Sony Xplod CD Player w/MP3 Playback...
Wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
Jun 02, 2008 | Pioneer DEH-P2000 CD Player
How to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
Aug 21, 2007 | Alpine CDA-9851 CD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Xtreme Sound WMS303 CD Player Logo
142 people viewed this question
Top Xtreme Sound Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
