Question about Juki DDL-8700
Cannon insert needle-assembly seems jammed
My needle fell out so I am trying to replace it.nit simply will not go up into the needle hole. I am sure the foot is down and the assembly is turned to the top. I have the correct needle and it is pointed the right way. When the previous needle fell out I had to jiggle the assembly and loosen the front screw. Could it have to do with this??
  • 64 Answers
The old needle broke off and is in the bar. theres a hole on the needle bar the allows u to stick a needle in and lever out the old broken needle. make sure the screw is loose. u can also rap the needle bar with a screwdrive handle to losen the needle. it should drop out, handy to have a small hemostat to grap the needle.
Posted on Jun 14, 2014
3 Suggested Answers
SOURCE: Juki DDL-8700--top & bobbin thread won't hold together for stitch
What bobbins do I use on a Juki DDL-8300
Posted on Mar 11, 2011
  • 159 Answers
SOURCE: Question about Juki Overlock MO-6704 Someone
Hi, yes I believe that will work, however you may need to re-adjust several time to get it perfect, my wife ( who's owned a couple industrial machines agrees ) use some scrap material to make adjustments and if possible ( with machine unplugged of course ) turn by hand to make sure it is not too far and could jam. I hope this was useful, please write back to let me know-even if not so we may try to help some more. Thanks for asking FixYa, and good luck-Prodzilla
Posted on Apr 23, 2011
I cannot insert a new needle properly, it seems to jam before fully inserted?
Take the screw out. Using onld needle, Clean out where the needle goes (old neede broke off up inside needle holder? )
Jul 13, 2014 | Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
LS 2000 sewing Machine, was working fine, changed the needle and it fell out, now I can't replace the needle
it's possible that the needle clamp holder needs to be replaced
a sewing machine shop can tell you for sure
May 31, 2012 | Brother Sewing Machines
Singer Confidence Model 7470 bobbin jammed, needles breaking, now won't sew
Sewing machines will get out of time, often as a result of broken needle. Search for sewing machine timing or take it for service, otherwise it will simply continue to break needles and possibly damage the machine.
Nov 11, 2017 | Brother Sewing Machines
I have a Brother XR-65. The needle bar fell out as I was sewing. I need a repair manual or some instruction on how to secure the needle bar in the machine. I have the bar itself and a pin sized piece of...
This was happening to me also - you have to tighten a different screw than the one that holds the needle in.
http://www.sewingpartsonline.com/needle-clamp-screw-brother-ls-2125-sewing-machine.aspx
My husband thought the screw was missing - it is actually a plastic screw with a hole in it for a tiny allen wrench.
You can see it in this picture also
http://www.sewingpartsonline.com/needle-clamp-babylock-brother-xz0001051.aspx
If you look at the photo of the screw I attached, you can zoom in and see it has a hexagonal hole.
It is above the flat head needle clamp screw (the one that holds the needle in)
It is REALLY annoying that this screw is mentioned nowhere in the manual, and the hex allen wrench is not included with the machine.
Kind of an important little detail, considering it holds the needle assembly together... you'd think that they would have told you about it.
Sep 09, 2011 | Brother Sewing Machines
Thread jams
Hi! I've had this happen to me many times and it is so very frustrating! First, take the bobbin out and also the bobbin assembly and clean the entire area of all lint, fuzz, little bits of thread....get it as clean as you can. Take out the upper thread too. Clean and oil. Change the needle. Make sure you're using the appropriate size and type of needle and thread for the fabric. Take off the needle plate and look for any nicks or scratches. If you've got them, you can get emery cloth from a good hardware store (often in the plumbing department) and polish them out (or mostly out).
Rethread the machine, carefully following the instruction manual. Use your basic, normal settings. Using a scrap of the fabric you're trying to gather, sew a seam and see if everything works ok. You may need to hold the top and bobbin thread firmly behind the needle as you sew the first few stitches (I find this little trick helps a lot to prevent birdsnests).
To gather, sew three parallel lines of long, basting stitches (you really don't need a special foot or special settings other than to make the stitch a long one). Don't backstitch, reverse, or lockstitch either end, and leave the thread long when you cut it. Pull the three bobbin threads and the fabric with gather nicely along them.
Something to keep in mind--if you're trying to gather very sheer fabric on a zigzag machine, you may need to replace the throat plate with the zigzag hole for a throat plate with a single, small hole for a straight stitch. I've run into this situation before, and ended up using one of my antique straight-stitch only machines to do the gathering.
If you don't have a throat plate with the single hole, you might try some light weight interfacing to give some density to the sheet fabric.
Hope this helps!
Jan 31, 2010 | Euro-Pro Sewing Machines
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    Make sure it’s attached securely.
    Make sure it's securely in position.
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Juki DDL-8700 Logo
27 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
