FISHER PAYKEL 420811USP
FISHER PAYKEL GWL15 is not powering on at all. Already changed the drain pump.
  • 106 Answers
SOURCE: fisher and paykel gw509 not draining, pump is clear
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Mar 04, 2009
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
SOURCE: Fisher and Paykel EcoSmart GWL15
tilt the machine to get to the bottom and there is an electric pump that you can remove with no tools, you twist if out. after that is removed you should see what has clogged your pump.. I spent 4 hours disassembling my entire machine , cleaning it, trying to find out what was wrong. And the fix could of just taken me 1 minute.. Next time... But at least I know how to take everything apart now, very easy and simple machine to work on.
Posted on Apr 21, 2009
  • 51 Answers
SOURCE: Fisher and Paykel EcoSmart GWL15 Machine won't
It sounds like you need to re programme the machine.
With the machine plugged into the wall and turned on and the headset turned off this is what you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Posted on Jun 14, 2009
SOURCE: Fisher & Paykel GWL15 washer won't drain. A
Hi There,You could bail out as much water as possible,Then If you lean the machine back against the wall,(with machine unplugged) you could remove the bottom plate (if fitted) and you will see the pump with a fan attached,Try turning the fan back & forth it may loosen the obstruction and you could then pump the water out before removing the pump for a service,A the front of the pump you will see a small plastic locking clip that needs to be held out while you turn the pump anti-clockwise for removel.Note treat everthing to be live on this machine if plugged in.(unplug machine before attemting any procedure) Best Regards.
Posted on Aug 21, 2009
Fisher paykel gwl15 won't power on
Did you pump make loud noises before the machine stopped.
if pump did, replace pump and get the fuse in the board replaced.
Oct 08, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and paykel gwl15 wont completely drain
Also check the clear pressure tube for blockages,
Blow air down the pressure tube to remove any blockages
that would prevent water level from changing.
Jan 02, 2012 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel GWL15 washer stops during wash, beeps, and displays the 3rd, 6th, and 8th lights. The problem began intermittently about a week ago; however, powering off, changing the cycle, and...
Hi just read your posting.Now error code 37 is called pump block error.This means either your drain pump is jammed, or the drain pump is blocked or the pressure switch tube that regulates the water level is kinked or blocked or the motor controller is faulty.Does your machine always drain the water?Please reply and let me know if your machine is draining the water and we can track the fault down.Looking forward to your reply.
Sep 16, 2010 | Fisher Paykel EcoSmart GWL15
The washer wont drain
Check clear filter //pump
Sep 29, 2009 | Fisher Paykel EcoSmart GWL15
Hi Dale..
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
