Question about Sony KV-DR29M69 29" TV
Sony KV-24LS35U green light flashing 11 times
Hi I have a Sony KV-24LS35U tv which was working perfectly until the other day when I went to turn it on but couldn't. It makes a clicking sound like its trying to turn on but instead the stand by light flashes green and blinks 11 times in a row. I have no picture and no sound. Any ideas on why this why this has happened and is it feasibly fixable? Any advise welcome Many thanks in advance Lesley
  • 398 Answers
The Sony error codes go up to 7, so when the standby light flashes 11 times it usually means that one of the clock or data lines deep inside the set is shorted to ground. This is not fixable from the front or through the remote, so the set should be serviced by a qualified tech familiar with Sony sets.
Posted on Aug 07, 2007
SOURCE:
Changed lamp and TV won't turn on, power light flashes 3 times
Red light blinking 3 times shows problem with lamp cover.
Lamp cover is not fixed securely in your tv after lamp replacement. Lamp cover is first thing that was removed to replace lamp, check lamp cover and make sure its back in place properly.
Thanks.
Jul 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv turning off
Hello
Sony FD Triniton Wega KV-36XBR400 service manual has no info for 11 times flash. It has info up to 7 falshes. Please count again. Error codes are in below pictures...
Regards,
Aug 27, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
SONY TRINITRON KV-28LS35U
Error 11 means the 8V supply is missing.
Check the power supply.
Jul 25, 2017 | Sony FD Trinitron WEGA KV-30HS510 30" TV
Sony trinitron wont turn on.
these sets have a flyback problem, the cure is usually replacement.
If you are unable to replace one, then you will require a technition.
Thanks Guy9
Jun 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-28HX15U
Most likely the flyback assembly, and or the horizontal output transistor failed. There is also a possiblity of some other faults that are putting the power supply in to the protect mode.
If there is a scan failure, it is possible that there is also some damage in the power supply.
The set will have to be serviced by a TV service tech.
Jerry G.
Apr 13, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony Tv Problem
The 4 blinks indicate the problem circuit, but I need the model number to give you the specifics. The category you entered is KV-36fs120 which is a 36 inch set. Please update this with the model number. It should be on the back.
Thanks,
Dan
Apr 03, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KV-DR29M69 29" TV Logo
682 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
