Question about Dell Computers & Internet
Need driver headphone jack
Headphone and mic don't work after new hdd jnstall volume control don't work either but volume can be controlled with keyboard
Bob.......what operating system do you have?
Posted on May 01, 2014
  • 38 Answers
SOURCE: fujitsu seimens scaleo P
Easiest way is to find the drivers through the "connect to internet" option which you get once you click on update/re-install drivers in the device manager. Sometimes this process does not work, so in that case you go to fujitsu site, support,choose your PC model and download drivers. Another option, go to driversguide.com, specify your PC model & download drivers.
Posted on Sep 25, 2007
SOURCE: Volume control on my keyboard dont work on my logitech LX710
The problem is with the keyboard drivres and you need to reinstall the keyboard drivers and try it again.
Hope this helps...
Posted on Feb 02, 2009
siawolf
  • 749 Answers
SOURCE: Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Posted on Apr 01, 2009
  • 136 Answers
SOURCE: Microphone suddenly stopped working
Try uninstalling and reinstalling your sound card driver. Also do the same for any software that has anything to do with your sound card. If this diesn't work, try restoring to a point before you had the problem. If you is usb and one is standard then it has to be soundcard or software, more then likely it's a driver issue.
Posted on Aug 12, 2009
graysand
  • 558 Answers
SOURCE: HELP! My new compaq presario cq60 built in
Do you have two mics or not,well if you have one you may have to delete one of them or both.Reboot the computer windows will install the drivers and this should fix this If not un-install the sound card drivers.Windows should reinstall once you reboot.However before you do make sure you have a copy of the sound drivers to reinstall.
Good luck
Posted on Sep 12, 2009
Testimonial: "I updated both of the drivers, one had an update and I restarted, mic worked, thanks"
Where can i find the sound on my laptop,i can't hear nothing on my lap top
Most generally, audio problems on laptops are not hardware issues to begin with, but problems with the software that controls the audio components.
Check the ObviousBefore delving into repair solutions, there is the possibility you can't hear audio from your laptop due to basic settings that have been changed. Check the volume level. If your laptop has physical buttons to control audio, make sure the mute button is off and the volume is turned up. Check the volume control on your operating system to make sure the slider corresponds to your button settings. Physical buttons on your laptop may stop working for a number of reasons, so be sure to confirm your software audio settings using the audio controls found in your operating system. Also, make sure nothing is plugged into the headphone jack. Headphones or any other audio device plugged into the headphone jack will mute your laptop speakers.
Reinstall the DriverA driver is a program that controls the hardware of your computer. Rule out file corruption of the audio device driver on your laptop by reinstalling the driver. This can be accomplished by locating the device in your operating system control panel and uninstalling the driver. When you reboot your computer, the operating system will search for available drivers for your audio device and install them.
Upgrade the DriverHardware manufacturers for devices on your computer frequently update drivers to resolve issues discovered after the original drivers were released. These updates could contain fixes to the very problem you have encountered that prevents the audio device from working properly. Just as you located your audio device to re-install the driver, use the device manager in your operating system to identify the specific sound device used by your laptop. Go to that manufacturer's website and locate the latest driver for this device. Download the most recent driver release and install it on your computer.
Check the Headphone JackThe most common point of failure in laptop audio hardware is the jack that connects your headphones or external speakers to your laptop. When this jack fails, it could mute the sound to your internal speakers as well, but more commonly it affects only the audio heard when you try to plug in your headphones. If you suspect the headphone jack is the problem, you should take your laptop to an authorized repair center for service. Depending on your model, you may have to replace a single inexpensive component or your entire computer main circuit board to remedy the problem. Thanks for using FixYa hope this will help your problem.Please don't forget to vote.Reymond
Oct 19, 2011 | Acer Computers & Internet
Headphones are working and mic is not working
The mics are of two types: electrostatic(cheap and modern) and old-stiled "dynamic". Old souncards were automatically switching to the mics type. Modern soundcards have to be switched manually.
In "sound properties" you first must check in that mic is turned on, mic volume in max and in all menues avd buttons find something like "mic amplifier boost"and turn it on. It's only non-standart mic tuning option in standart systems. All other problems in defects. Soundcards can be verifyed by so:
(with maximal speaker and mic volume) many times plug in and plug out any reacheable mics and headphones to the mic connection nest (hole), and listen(or recording) resulting scratches. If scratches or other related sounds are abscend(only noise), soundcard is bad. The mic problem may be in "jack left-right interconnection". This useful thing may hang some improper cards. Also that cards often cannot work with dynamic type. And they very sensitive to a manufacturer, and model of mic.
Problem may be also in configuring multimode speaker nests in 5_1(7.1) cards like REALTEC - the mic nest may be switched to the speaker output mode. Open Realtec's control center(in control panel or quicklaunch icon) and check in mic nest to "mic mode" or switch mode from 5.1 to stereo speakers.
May 17, 2011 | Computers & Internet
I plug it directly into my pc and it wont record on my music programs.Does this mean it is broken?Is there something im missing?.And it was purchased new but came with no directions,is that right?Also...
There is no volume adjustment. You would have to use the volume controls in the PC "control panel". Not all PC's will be compatible with this mic, as this mic is monaural, not stereo. You may have to use a 1/8 jack monaural to stereo jack/plug for the mic. Be sure and set the volume levels for both the mic and headset in the control panel AND UNMUTE the mic.
May 07, 2011 | Yamaha Cm500 Headphone With Built-in Mic
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
My Logitech headphones mic won´t work with windows xp. Can hear, don´t hear me.
Your headphone mic is all right. The problem is with the sound driver you are using. Many a time the headphone jack are not properly connected so it may be another issue for not working of your headphone. Your operating system is all right check out the sound driver setting from the control panel.
Good Luck
Mar 02, 2009 | Logitech (980361-0403) Headphones
I cant use my microphone on my skullcandy lowrider headphones
OK OK OK, the lowriders use dolby digital with WMA playback, and there is a setting in ur xbox settings where u can change that. BUT UR NOT DONE YET. press the Xbox button, go to settings go to prefrences, go to mic and check the box that sais "play through both." and now u can hear the ppl and talk. however, what they dont tell u is that the mic interfears with the WMA, so all u need to do is just buy an inline volume adjuster at walmart (wally world) for like 3 bux (the one that coems with it is regualted by FDA or wtvr and has no sound which is verry unlike skull candy). THESE headsetes arnt cheaply made at all 2 tell the truth, they shooda came with instructions, but once u get em going, they r insane! i have a pair of turtle beach x5s and its nice, but not as good asthe lowriders. and anotehr feture they dont tell u, if u get a volume adjuster with the "base gain" swicth, it works on the lowriders, so u can add a little rumble and umph to ur headset.
Jan 06, 2009 | Skull Candy Lowrider Headphones
I have a Dell Inspiron 1525 without the webcam .. when I use my headphone jacks in the front of my laptop I'm able to hear but the they can't hear me through my headset microphone. They're only able to...
Be sure that your headphone mic plug jack is plugged in to the mic jack (right-most jack) and not the second headphone jack. If so, check your sound setting in Control Panel and make sure the mic is enabled and the volume slider for it is up.
Dec 07, 2008 | Computers & Internet
Mic doesn work
same thing happened to me, it wouldn't even work when i went to control panel -> audio devices -> mic test   i think i'm just going to return it for a different model.
headphones worked well though
Sep 23, 2007 | Logitech Premium Headset
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
