Question about Miele Novotronic Premier 500 Front Load Washer
Miele washing W3725 does not start
My Miele suddenly stopped working at the very last cycle, the spin cycle. I shut down my house safety switch. When i turned the safety swicth back, and plug the power cable back to power point, but the machine is no longer works. There is no error code since the machine is completely died. your help please.
  • 16 Answers
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Posted on Feb 08, 2008
  • 16 Answers
SOURCE: miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
  • 70 Answers
SOURCE: My Miele Novotronic W 844 Washing Machine will not
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Posted on Mar 30, 2010
SOURCE: washing machine not spinning
I had a similar problem and about a week later it didn't wash at all.
Turned out the water inlet valve (one of the three) was faulty. The rubber seal/seat had a small hole and wouldn't open to allow water into the machine.
I wasn't prepared to pay the $213 for a new one so I went to our local appliance spares place and found one that was similar and used the rubber seal/seat from that to replace it. It was an electrolux single inlet valve part #360313 (from memory). Cost me $37. Could've got it for $22 delivered off ebay but I needed it asap.
Posted on Jun 05, 2010
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
I have a Miele w3725 washer that cuts out after 30 seconds to a minute. If I unplug it for a bit and turn it back on it will start but the same thing happens again. Any suggestions?
Hi Ben, The link below could hold the answer... Please read and then click the link for more...... I hope this helps...CHEERS..
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
http://removeandreplace.com/2013/05/13/washing-machine-or-washer-dryer-is-not-spinning-draining-how-to-fix/
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 05, 2016 | Miele Washing Machines
Miele w3725 won't start
If the Start LED keeps flashing, either the door is not closed properly, or the door switch is broken.
Mar 01, 2015 | Miele Washing Machines
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
Washing machine will not agitate or spin. We can hear the motor running with a shrill noise.
Under the door there is a switch -if broken it will not let the spin cycle spin - its a safety thing.
like when you open the washer door when the spin cycle is on and it stops spinning until you shut the door again, when you shut the door the switch activates.
cost around $3.00 - put in with a screw driver
good luck -- aloha
Feb 13, 2011 | Roper Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Magic Chef machine is 17 years old, but looks like new, so I hate to part with it. It stops during the SPIN cycle. I fiddle with it, like turning the dial around a couple of times and it will come to...
check the lid switch,it is located in the area where the lid lands on the washer housing when closed it is a safety feature that shuts off the machine if you open the door during the spin cycle,they can get touchy due to vibration from running,also check your balance ring,if you have a severly unbalanced load it will stop the machine
Jan 25, 2010 | Washing Machines
Maytag toploader model pav2300WW
Do you hear the motor activate during the expected spin cycle? If yes, then there might be a gearbox or clutch assembly issue. If not, it might be as simple as the safety switch not being engaged as the rest of the cycles might operate properly even if the safety switch is not engaged.
If the washer totally shuts down when the spin cycle begins, look at the safety switch circuit.
Mar 09, 2008 | Maytag LAT3600A Top Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
