Question about Samsung SyncMaster P2770HD - LCD monitor - 27" - 1920 - P2770HD
Take Apart Samsung monitor
How to take of back
Samsung 931B monitor (doesn't turn on)
Check for blown capacitors on the power supply board, this is a very common problem with LCD monitors. Here is a link to a web article showing what to look for. The second link is to a source for capacitor repair kits for that series monitor.
http://www.ccl-la.com/blog/index.php/capacitors/
http://www.ccl-la.com/catalog/index.php?cPath=21_33_67
Jan 14, 2013 | Samsung 913B 19 inch LCD Monitor
White screen on a Samsung 206BW after it fell onto the floor
Something is wrong inside the monitor. I would call samsung support and get an answer from them. You could probably trade your monitor in aswell if its still under warranty.
Apr 18, 2010 | Samsung 206BW Monitor
How to remove the back of Samsung 940MW LCD TV
You will need to take a small flat blade screwdriver and insert it between the two halves of the case and gently pry the two apart. There are latches around the case that just need a little pressure to release. Once you get a few released the rest will pop open as you pull the halves apart. We have some pictures posted on our web site at: www.ccl-la.com Look in the monitor repair section. THere are several repair guides for different brands with pictures of what the release latches look like. If you have any questions just call us at: 318-447-9040
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Dec 01, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
I need to open the back of the Samsung TD220 LCD TV
Care is to be taken? these cases are engineered sometimes with interlocking panels see if you can wedge a a single edge razor blade between the grove of the mated panels and wiggle it see if it moves a little.
If so work it around using danty steps to find the interlocking area the rest is the tought part which one is the release side.
Jul 28, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 170 MP LCD Monitor Disassembly
The plastic case also has latches along the sides, top and bottom. Take a small flat blade screwdriver and go between the 2 halves of the case. The 2 pieces should open just a bit, now move the screwdrivers along the seam between the 2 halves. about every 2-4 inches there is a clip that needs to be released. You can release it by applying a small amount of pressure by each clip and moving down to the next one while pulling the case apart.
Buddy
Corporate Compuer
over 21 years repairing PCs and printers
Jun 17, 2009 | Samsung SyncMaster 17" TFT LCD Monitor
Samsung 22'' lcd screen turns on see something for half a second then turns off tried to hook up different computer same problem had two hooked up tot the same computer and same problem on both screens two...
I have had 3 Samsung monitors do the same thing. Before you call Samsung, completely disconnect the monitor from all computers, then power it on. If the monitor is okay you will get a screen that will say something along the lines of "video source not found" in what I believe will be a blue box on the screen.
If you get nothing the internal boards are bad and it is time to send it back to Samsung. Go to Samsung's website, if you have not registered the warranty then do so, you will need the cash register receipt or the invoice from where you purchased the monitor -- you have to send an electronic copy to Samsung to register the warranty. Once registered begin the RMA process. If the monitor is within the warranty period Samsung will actually UPS a replacement montor to you. The process is simple, you go to the UPS Store unpack the replacement, put the sick monitor in the box from Samsung, UPS puts on the prepaid preprinted label, you go home with good monitor and the sick one goes back to Samsung.
May 09, 2009 | Computers & Internet
Samsung 931B monitor - shadowing
I have the same monitor, and twice I've experienced this exact problem. In my case, the video connectors have relaxed. If I wiggle the cable, I can make it better or worse, so it's time to disconnect, reseat. I don't know if it will work for you, but it's free!
Feb 20, 2009 | Samsung 931BF 17" LCD Monitor
How do I take the cover off samsung 930B monitor
The front and back covers snap together. Some come apart easily others are very reluctant and will break some of the retaining clips as you pry the front and back apart. Usually this does not result in a problem as there are enough retaining clips to hold it back together.
Most of these do not need bulbs. Usually just replace the power supply electrolytic capacitors that are bulging.
Monitor Mike
Jan 04, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Dell computer windows xp pro. samsung syncmaster 731b cannot install right. says comp. cannot support default monitor installed ,
I need help monitor went blank and when I try to turn it back on it only blinks at the power button. took it apart and everything looks ok.
Mar 26, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Samsung SyncMaster P2770HD - LCD monitor - 27" - 1920 - P2770HD Logo
120 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
