Braemar GH65 PC unit?
Hello, I was told that our heating unit (braemar GH65) needs a new PC unit. What is this and where can I find it? I can't find a reference to it in the instruction manual.
SOURCE: braemar evaporative air con with tekelek tek297
Maybe to late but i do have a TEK297 and possibly able to help with the wiring. I also have a problem with identifying a resistor on the board which you may be able to help me with.
Cheers Ron
Posted on Feb 09, 2010
  • 34 Answers
SOURCE: Braemar cooler turns itself off after it has run
most likely has a gas leak and cuts out when the gas pressure drops below its' cut out pressure. nead to find leak and repair, then charge unit to running pressure
Posted on Apr 24, 2010
kapishtech
  • 2272 Answers
SOURCE: Cannot reset remote for braemar Ecostar Ducted
check the remote batteries.are they weak or very old.Or may be the remote button circuit is faulty.actual procedure is to press the set button and change the settings and select the required settings and make changes and set button again to save changes.But id set button is not functioning.Then remove and replace the battery in remote also replace the battery and recheck. Thanks.
Posted on Jul 18, 2010
SOURCE: plastic pipe fitting into the
it is best n cheaper to replace this pipe than to try n repair it. I dont knw hw old it is but m sure thats a sign of a weaknes, another point wil start leaking again if u repair this one, replace it.
Posted on Jun 09, 2011
SOURCE: My father has to replaxce
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Posted on Sep 01, 2011
I have a braemar model TE420 and when a press the on button on a confort control , the control is calling for Heat but the On & Wait signal is flashing and doesn' t start
Youtube doesn't show the Braemer specifically, but take a look at these and see if any of them work for you?
https://www.youtube.com/results?search_query=braemar+TE420+dishwasher+on+and+wait+light+flashing
Oct 04, 2014 | Dishwashers
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Sep 01, 2011 | Heating & Cooling
I have a Braemar Spectrolink Controller, which has suddenly lost all power and the display is completely blank. I have removed the controller thinking that there would be batteries, but where the batteries...
it gets its power from the unit via the data cable. go on the seely international website or the braemar website and they can put you in contact with another dealer in your area. get it fixed while still in warrenty.
Feb 19, 2011 | Honeywell Programmable Thermostat Heater
Cannot reset remote for braemar Ecostar Ducted heatin. Need to reset time and day. Would like to reset programmes also however when i hit the set button as per instructions in little book provided the...
The Braemar heater I have is wired directly to the control unit. The only way to reset the time is to turn of the heater for 5 minutes - the remote display should clear, and turn it back on (takes a minute for remote to come back on) the time will be flashing - use the Up and Down arrows to set the time, and SET button to set the day of week.
Jul 18, 2010 | Heating & Cooling
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
