Siemens l9za lcd monitor - Computers & Internet
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Dec 13, 2010
Transformer circuit diagram L9ZA-A1
http://www.eserviceinfo.com/index.php?what=search2&searchstring=fujitsu+siemens+L9ZA+lcd+monitor
Jun 13, 2014 | Samsung SyncMaster 740N 17" LCD Monitor
My lcd monitor model no. L7ZA NOT showing no picture comming & bilnking blue led contenue so plz help me
your computer unit couses the problem. do you try other monitor or computer? try to check the cpu if it is working.
Aug 20, 2011 | Fujitsu Siemens Siemens Basic Line 38B2-M...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor does...
Try connecting each monitor to a different desktop/laptop computer, to rule-out the possibility that the video-card on your own computer is the cause of the problem.
Sep 29, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
No electricity on screen. How do I connect LCD doesn't work
Which is cheaper:
* spending $50 to $75 to have a qualified technician "trouble-shoot"
* spending $50 to $100 to buy a used 17" (not 15") LCD monitor?
Jul 31, 2010 | Fujitsu Siemens Siemens Silver Line S5 15"...
Fujitsu Siemens 19 W LCD monitor: no image
Temporarily connect a different monitor to your computer, to see if your video-card is the problem.
Temporarilyh connect your monitor to a different computer (desktop/laptop), to see if your monitor is the problem.
Try a different "data" cable between your monitor and your video-output port.
Jun 12, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
My siemens LCD monitor back light turns off after 1 sec
You need to check out caps in the power supply section first, then check the backlight inverter circuits for bad fuse, transistors. It can also be bad lamps. See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 05, 2010 | Fujitsu Siemens Siemens Basic Line B15-1...
Pixels look blurred on new Fujitsu Siemens 17inch LCD Monitor
What are you using as a interface between your computer and monitor? It sounds like you may be using a digital analog converter. Example would be a 15 pin dsub VGA to DVI adapter or vise/versa. If your using a purely digital interface like Display Port, DVI, or HDMI then you have a bad controller in your monitor. Try to do warranty claim if this is the case.
Oct 31, 2017 | Fujitsu Siemens Siemens B772-1 17" CRT...
Computers & Internet Logo
David Payne
David Payne
