Question about Vizio VO Televison & Video
Where is the Advanced Audio Menu on a Vizio GV47L
My Vizio GV47L doesn't appear to have an advanced audio menu...which I need to access to turn on the digital audio output. I have an external speaker set up through the digital output, but it is not working. I went to the Tuner Menu and it is still not there.
Turk_97
  • 131 Answers
SOURCE: Unable to access digital audio output options
Well you also need to have a digital feed to the television. example: When I run my optical cable from my dvd player to my television directly. I went in to my menu options on my source and enabled this. If you are wanting to run this feed to your a/v amp? You may want to run the original feed from your dvd player to your amplifier directly, you will get a sound quality that is far superior to what you seem to be doing here.
Posted on Sep 24, 2009
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
SOURCE: I lose Audio from internal speakers Vizio
This issue is actually caused by my cable box. Access the audio SETTINGS on Hand held Cable Remote, and turn on the HDMI and or "Digital Audio Out" option. found on 'more' settings list. This should fix the issue. I had assumed the Cable companeis 'Boot' would have installed this feature during its initialization.
Posted on Dec 20, 2009
SOURCE: I am trying to connect exteranal speakers to my new Technika TV
There may not be any way to do this. If there is no audio OUTPUT option, you may need to open up the set and wire things directly inside - a bad, warrenty ending idea - or buy a new set.
Posted on Dec 07, 2010
  • 11800 Answers
SOURCE: I can not attache an
Unfortunately this tv doesn't have analogue audio outputs so connecting one by using a 2 headed RCA cable is impossible. And it gets worse : this tv was manufactured in 2 versions with the exact same number - depending on where you bought it it may or may not have an digital optical audio output, also known as TOSLINK.
If your tv is the version without it then it will not be possible to connect an HTS to it directly. But there is another possibility - the version without the TOSLINK has connectors for external speakers and you could use those. You will need an attenuator (connecting them directly to the inputs of the HTS would instantly fry the HTS) and from it to the inputs of the HTS. Its extremely simple to make one yourself, al you will need are 4 resistors. Read more about that here
http://www.tkk.fi/Misc/Electronics/circuits/speaker_to_line.html
Posted on Feb 21, 2011
No audio to internal speakers,audio out to amp is good.
THIS AUDIO PROBLEM PERTAINS A FEW DIFFERENT NAME BRANDS AND TO MOST VIZIO Tv MODELS
MADE IN THE LAST 2-3 YEARS MAYBE EVEN 4+ I'M NOT SURE
WHEN IT STARTED.
I do believe your model is equipped with the SRS features which IS a formatted audio enhancement . Anyway go into the advanced audio settings in Tv's menu and TURN OFF the SRS tru volume leveling & the SRS tru surround feature. Additionally in the Tv's menu also has an option to turn off the internal speakers. And another common pitfall that I see happening to people. Is check the PCM and or LPCM option in both your Tv & your cable/satellite box's audio menu setup/settings. LPCM is Limited Digital Audio and PCM is Variable Digital Audio (VOLUME AMPLIFICATION) but
because it is a digital signal the two formats conflict, and the audio
will in and out.
WHEN IT STARTED.
P.S. YOUR WELCOME I SAY THAT CAUSE QUITE OFTEN IT IS
THE AUDIO PROBLEM VIZIO CUSTOMERS ARE HAVING!!!
Jason Draimen AKA "AVALANCHE" !!!
Apr 01, 2013 | Vizio VF550M 55 in. LCD HDTV
Tip
Instructions for Unlocking BlackBerry phones ( All Models)
<span><span>Always the Best way to Unlock Your Phone is by using the MEP2 code or Unlock code. First you should<a href="http://unlockgenie.com/"> Purchase the Unlock code from a Trusted Vendor.</a><br /><br />After u got the code follow the instructions below......<br /><br />BlackBerry Unlock Instructions (9800)<br /></b><br />* Insert a foreign SIM Card<br />* Power on the phone<br />* When prompted, enter your unlock code<br /><br />BlackBerry Unlock Instructions (83xx/85xx/88xx/8900/9000/9300/96xx/97xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />BlackBerry Unlock Instructions (95xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Tilt the phone horizontally, click the BlackBerry button and Show keyboard<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />o *If MEPD doesn't work, try MEPPD<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />o *If MEP2 doesn't work, try MEPP2<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Blackberry Instructions (81xx/82xx/9100)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Old School BlackBerry Instructions (87xx & Older)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Hold ALT key and type 'MEPE' (user will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked</span></span>
on May 05, 2011 | Cell Phones
The angry birds for psp does not run and shows problem/error 80020148
Is your game in a memory stick?
Try this:
1. Goto Recovery Menu (turn off then hold R and turn on)
2. Configuration -> Use NO-UMD (Disable it)
3. Go all the way back to main menu
4. Advanced -> Advanced Configuration -> (Disable all of them)
If that doesn't work, update me before rating my answer, so I can advice another solution.
Aug 20, 2011 | Sony PlayStation Portable (PSP) Console
DVR remote won't work w/ visio tv on. Dish says i need to turn off "power save mode". How is that done?
On the vizio remote go to menu then picture then click the more button then advanced pic then turn off ambient light sensor and bscklight control. I also had to play around with the backlight #
Jun 04, 2011 | Vizio L37 Television
I have the vizio GV47L and my stereo Sony ampifier doesnt work properly when I plug it in the audio out. I have to turn the volume up on the sony in order to hear any of the sound. There is no place to...
For this I would get in touch with the service rep for your set. They should be able to answer the question.
There are a few possible issues. There may be a menu setting somewhere to properly set the levels of the audio output, there may be a defect, or there may be a compatibility issue.
Jerry G.
Jan 06, 2011 | Vizio VO47L 47 in. LCD TV
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
My Vizio Tv volume does not work properly. When its at volume 100 it sounds like volume 50. What could be the problem? My question is how can I fix it? Let me know...
May 10, 2010 | Vizio VF550M 55 in. LCD HDTV
No sound after I change the channel. If I turn the
There is an incompatibility between Fios and Vizio audio. To fix the problem, on the Fios box, press "Power" then "Select" then "Menu", one right after the other. This accesses a secret menu on the Fios box. Using the arrow keys on the front of your Fios box, arrow down to "Additional HDMI Settings" then press the right arrow. Another menu will appear (may take a few seconds). Arrow down to "Audio Out" and press the right arrow to change from "Auto" to "L-PCM". Press the Power button to exit the menu. This should solve your problem. Thanks to Vizio tech support for the answer.
Apr 29, 2010 | Vizio L37 Television
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
Dec 19, 2009 | Vizio SV470XVT 47 in. LCD TV
Televison & Video Logo
117 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
