Question about Zenith A27B33W 27" TV
Television There is no sound or picture on the television screen, only a eeeeeeeeee noise.
  • Anonymous Apr 14, 2008
    My 27" was working when suddenly it went pop and went off with a subsequent eeeeeeeee noise being emmited.Also slight smell of burn . Humidity was high at the time.Any ideas? Many Thanx,Paul
I found a similar problem with another Zenith tv and it sounds pretty close to the problem stated above. This was threir solution to it...
REPLACE all 3 caps; 560pF 2KV p/n 22-8386-05 (Buy from Digi-Key good parts) even if one still looks good, very common failures and 9 out of 10 times if
the H.O.T. is also shorted the Fly should still be good.
Hope it helps
Posted on May 04, 2008
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
No video but sound
its the bulbs and or soder connections loose needs resoldered. mine was a 60" and cost 893.00 to fix it.
Aug 18, 2014 | Televison & Video
I was watching my television, then suddenly I hear a "pop" noise and the screen goes blank with no sound. I then hear a faint, repeating electrical "clicking" noise toward he front of the television. ...
Hello
Your TVs LOT [Line Output Transformer] may be got shorted. It can be replaced. There is no need to replace the picture tube. The noise you hear from your tv is due to this short. Contact any service technician or authorised service center.
Oct 18, 2010 | Sharp 36F-830 36" TV
My tv has sound but no picture except for a blue screen
My television worked this morning and now only shows a blue screen. The sound works but no picture except for a wavy blue screen.
Jan 22, 2010 | Televison & Video
The humming noise from my hitachi 42hds69 television seems to have gotten a little louder. This humming sound is more prevelant on various stations. The humming sound seems to be normal/better on dark...
usually it means your screen is going bad unless it is a fan or some mechanical part thats humming if it comes from the screen itself the screen panel going bad.now you can check cables and eveything else for this a signal loss type of short but if you have allready checked all cables or recievers or connected devices for this then its a simple main panel humm means a bad screen panel sorry to say but i hope this helps..
Jun 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
N o picture just static noise
The symptom sounds like a dead tuner and the screen blanking may be due to missing video synchronization signals which may cause either blanking or 'blue screen' on some sets.
This could also still be because of a failing power supply although they will generally just cause no turn-on at all.
I would first substitute another TV just to be sure your signal source (cable or satellite) isn't causign the loss of signal.
May 25, 2009 | RCA R52WM24 52" HDTV Projection Television
Big screen no picture and makes heart beat noise?
can be a faulty mains board, does the sound still work? if not, can be mains board, and at last if there is a continuous clicking sound it a faulty power supply.
hope that help
pls rate me!
Mar 21, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
TV will not turn on. It makes a nonstop clicking noise.
Sounds to me like the high voltage power supply is attempting to fire off the metal halide lamp without success.
Nov 24, 2008 | Philips 55PP9352 55" Projection Television
Pioneer 501-HD 53 Rear Projection TV- No Picture or Sound
your input board might be bad, does it work on any other inputs?
Oct 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Televison & Video Logo
160 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
