Question about Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
Hoover savvy reset button for brush roller - Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Posted on Jan 29, 2008
landsend
  • 1066 Answers
SOURCE: hoover windtunnel vacuum roller brush doesn't
does the motor turn?  if it does replace the belt.
Posted on Apr 04, 2009
CorvetteKing
  • 108 Answers
SOURCE: On my Hoover Savvy U8174-900 on carpet setting,
Hoover savvys have two very common problems that cause this. The first and most obvious is the belt that you checked already. Many times the belt is tight but those particular belts have teeth and should you lose any teeth on the brushroller OR the belt it can cause this.
The other problem this is a symptom of is a bad switch in the handle. It sounds odd but the switch assy in these machines controls 2 motors, one that causes vacuum another that causes the belt to turn! Often time that switch assembly is bad and the smaller motor that drives the belt does not run when the handle is in a certain position. This causes your brush to stop but since the louder bigger vaccum motor is still operating you never hear the small one quit. I would run this again and listen for a difference in sound. In this case you will buy a replacement circut board that is installed in the handle (i usually replace the entire handle assy, the small extra cost is worth the dependability as nobody can seem to determine for sure what makes them go bad)
You can get the parts from any hoover service center, use their dealer locator to find the nearest one. Be sure to take the old parts in and compare when buying new, hoover makes running changes to their product so 2 machines with the same model number can be different.
Aside from a stray bad or pinched wire you're more than surely dealing with one of those two items. I'd focus on the first paragraph as that is by far most common and least expensive.
Best of Luck!!
Posted on Jun 09, 2009
  • 11 Answers
SOURCE: hoover savvy will not move
the reset button is in the handle, under the cover for the switch. remove the two screws and pop apart. you need to pull up the little post under the lever switch, and push it back down. hope this works for ya.
Posted on Aug 14, 2009
Hoover savvy will not move
Jul 01, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Hoover savvy upright, replaced belt, but brushes will not turn
One of the common problems with the Savvy models is the upper handle switch. However if it is newer, you may also have an issue with the lower cable. To test it, turn on switch in carpet mode, and at the bottom rear, wiggle thr exposed black cable. if the roller starts and stops then it is bad and needs replacement. the cost of the part is about $10 but labor intensive to replace.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Feb 26, 2009 | Hoover Vacuums
Drive and brushes stopped
Look for a missing belt that may have burned off or broken. Was there a burning smell at some point before the roller quit turning? If so, the belt must be replaced. I would also look at the ends of the roller to see if there is any string, hair, etc. that might be binding the roller that needs to be removed.
Jan 24, 2009 | Hoover U8125-900 Savvy Bagged Upright...
The rollers on my hoover widepath won't turn
On this model the brushes will not turn on unless the handle is tilted back and the switch is set to carpet. if you are already doing this, then one of the likely causes would be the gear motor assembly. If that sounds expensive it is costs around $65.00. for the part only
Jan 16, 2009 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Savvy Belt
put the belt over the brush roller first then put the brush roller on then you can start one side of the belt on the motor shaft and turn it will make its way onto the gear on the motor
Dec 28, 2008 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Hoover widehead bagless vac
is your brush roller and hadlight working.if not call me at 314-628-9153 and i can help you
Aug 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Lost roller on Savvy
need more info spring and washer don't tell me anything.do you have all the parts.i think your talking about the spring washer that keeps the brush roller from locking up.if thats what your talking about remove the bearing cap off the end of the roller brush.lay it inside the roller concave ppart of the washer down put the cap back on.if both washers came out of thesame side put the spring washer in first then the flat washer
Aug 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Roller brush on vacuum will not turn
This other than it's capabitlities to clean is a very fragile product for this reason. Everytime you get something wrapped around the rollers it quits allowing the roller brush to turn. My repair guy says it is in the switch on the handle it causes some sort of short or something. Everytime it happens it costs me $45-50 to get it repaired the first time it was still under warrantee next time I'm just going to buy something with a better track record and a longer warrantee. I think Dyson has a five year warrantee.
Oct 05, 2007 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U8145-900 Savvy Bagless Upright Cyclonic Vacuum Logo
66 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
