Question about Sony Handycam DCR-TRV6 Mini DV Digital Camcorder
Sony dcr-trv6 shows c:31:30 and beeps
Have a sony dcr- trv6 mini dv camcoder. when i turn it on it beeps and shows c:31:30 on the lcd display screen. i tried a new battery,tapes, and keeping the door open for hours. and i use the reset button. it still does not work. HELP ME! thank you.
  • dre smith Aug 07, 2007
    still waiting for an answer?
  • Anonymous Mar 31, 2014
    tried unplugging and leaving open than turn on,slides out but does not pop tape up
  • 169 Answers
The capstan motor of your camera is stuck up....check the capstan motor is there is some debris insert at the sensor...if nothing you find check also the bushing at the upper part of the motor....
Posted on Aug 10, 2007
  • christian tope Aug 11, 2007
    if the motor running too past...check the sensor if there a scratch or damage at the sensor....if nothing you find ...check the resistance of the sensor about 200 ohms to 1 kilo ohms...all of the must have that resistance not too far to the other pin..
5 Suggested Answers
SOURCE:
SOURCE: trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Posted on Aug 08, 2007
  • 169 Answers
SOURCE: sony dcr-trv6 beeps and shows c'
check the capstan motor if it is stuck up... find if there some debris inserted at the sensor...if nothing you find check also the bushing in the upper part of the motor
magic seadog
  • 38 Answers
SOURCE: trouble using dcr-trv6 mini dv camcorder
This is a common failure in this model and unfortunately will not be resolved without a qualified servicer. The error code indicates a message for lack of reel motion. Most often it is an electronic connection problem and not an actual reel problem. Good luck, magic seadog
Posted on Aug 12, 2007
SOURCE: sony dcr-trv6 beeps and shows c:31:30 on display
need manuel for cannon camcorder zr45mc
Posted on Dec 31, 2007
How to troubleshoot a video camera when the LCD screen is dark or has no display, in a Sony handycam DCR TRV22E mini
If you see correct picture in Eye Piece view finder but dark picture in LCD that shows problem with connecting flexible wire between LCD board and Camcorder main board. It got cracked/ damaged or broken after some time due to open/ close of LCD in its position.
Replace that flexible wire and problem will be solved.
Post back further question if you have any.
Thanks.
Dec 08, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony dcr-hc20e problem on screen in standby mode
my computer is unstalling all files and now my cd software to my sony dcr-hc20e digital video camera recorder was lost.pls help to find a free cd software to my sony dcr_hc20e digital video camera recorder
Mar 13, 2008 | Sony Digital Mini DV Pal Camcoder...
Sony dcr-trv6 unable to load tape in deck
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Aug 10, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Trouble using dcr-trv6 mini dv camcorder
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony dcr-trv6 beeps and shows c'
Trouble working sony dcr-trv6 mini dv digital camcorder
Sony Handycam DCR-TRV6 Mini DV Digital Camcorder Logo
1,072 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
