Question about Sony Handycam DCR-TRV6 Mini DV Digital Camcorder
Trouble using dcr-trv6 mini dv camcorder
I have a sony dcr- trv16 mini dv camcoder. when i turn it on it beeps and shows c:31:30 on the lcd display screen. i tried a new battery,tapes, and keeping the door open for hours. and i use the reset button, follow owners manual it still does not work. HELP ME! thank you.
  • 38 Answers
This is a common failure in this model and unfortunately will not be resolved without a qualified servicer. The error code indicates a message for lack of reel motion. Most often it is an electronic connection problem and not an actual reel problem. Good luck, magic seadog
Posted on Aug 12, 2007
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
How can I get the fader on my Sony DCR-TRV16 to turn off?
Press again same fader switch to get fader function disable.
Feb 12, 2009 | Sony Handycam DCR-TRV16E Mini DV Digital...
Hi i have sony difital handycam model DCR-TRV16E want to install in computer looking for the diriver. Please if you help me
Your drivers are available here:
http://www.sony-asia.com/support/download/1656/product/dcr-trv16/modelfirst
Please be sure to rate this solution. Thanks!
Nov 11, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sont DCR TRV16
Smack it!!
And have a look at www.camerahacker.com
Aug 14, 2007 | Sony Handycam DCR-TRV16E Mini DV Digital...
Sony dcr-trv6 unable to load tape in deck
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Aug 10, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony dcr-trv6 shows c:31:30 and beeps
the capstan motor of your camera is stuck up....check the capstan motor is there is some debris insert at the sensor...if nothing you find check also the bushing at the upper part of the motor....
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony dcr-trv6 beeps and shows c'
check the capstan motor if it is stuck up... find if there some debris inserted at the sensor...if nothing you find check also the bushing in the upper part of the motor
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Sony Handycam DCR-TRV6 Mini DV Digital Camcorder Logo
152 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
