Question about Sharp Office Equipment & Supplies
Sharp How To Connect
What pins do I connect an infineer 6255 to a sharp mxm363 copier CN11:1-16
  • 2072 Answers
SOURCE: sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
If this does not clear the problem the fuser will need replaced.
Posted on Feb 21, 2008
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
mickspaceNET
  • 115 Answers
SOURCE: Sharp -COPIERS - AR-5316
@subscribe
Sharp does offer a linux driver, look for a cups driver.. Sharp offers drivers for mac, linux, hp output servers, as/400, windows etc... of course this varies on model number...
Posted on Nov 22, 2008
tehnik_bdg
  • 91 Answers
SOURCE: problem on sharp copier ar m-236 h4-01
Try reset the error code by pressing [#] [INTERUPT] [C] [INTERUPT] [14] [START]. If error still exists check the thermostat and heater lamp of the fusing unit.
Posted on Jun 05, 2009
M2Tech1
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
WANT TO CONNECT MY SHARP COPIER AR5320E TO MY PC FOR PRINTING AND OTHER RELEVANT USAGE
first insert the installation cd and install the driver then connect the copier to pc with usb port.
Aug 07, 2010 | Sharp AR-5320 Black and White Copier
Installing sharp 5127 photocopier on my computer
Install printer card into the copier. Put installation cd into the computer and click setup, follow on-screen menu and connect usb cable when prompted then complete installation.
Nov 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
Sharp copier model SF2530 F1 flasing and copier
Hello sir; F-1 is sorter problem, did you connect sorter with machine, turn power off and check th connecter .
May 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M205 is not working with windows vista home edition
1. Uninstall the previous driver
2. Re-install the driver ( do not connect the usb cable at this time )
3. After driver installation, the pc will ask you to connect the usb, do this and it should be OK
Apr 01, 2009 | Sharp AR-M205 Copier
Sharp Copy Machine
You don't say if you are using a server/client network or a peer-to-peer. Go to START >printers and Faxes >Add a printer >Next and select A Network printer select Connect to the printer and then enter the path to the printer eg \\server\printer name
Oct 01, 2007 | Computers & Internet
How to connect my Sharp LC-26DA5U to my computer as a monitor
There are two possible problems: 1. You are connecting a 15-pin (on the laptop) to the 9-pin (on the TV) connection. This isn't the video-in connection for the TV. The TV has a DB-15 connection near its DVI input connector. You should be using a 15-pin to 15-pin cable. The DB-9 connector on the TV is a serial port for servicing the TV. 2. You aren't enabling the external video port for the laptop. Try hitting Fn+F5 on the laptop to cycle between the three display modes: laptop only, laptop + TV, TV only. Make sure to wait a few seconds after hitting Fn+F5 to let the displays sync up.
Feb 20, 2007 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
