4 didgit code was put in by my child and she does not know what it was. locked and only way is to find where she did it. it will unlock but you still cant change code
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
If you can remember the PIN Code previously set on your device you will be
able to change the Pin on your device easily. You can change the PIN on the
unit by doing the following:
All Nuvi's excluding 3xx and 6xx
Within this section you can add or change a PIN.
When the Garmin security lock is set it locates the units current GPS location.
If you are trying to change the Garmin Lock and are not within the same location
to where the Garmin Lock was set you will need to revert back to this GPS
position.
Once at this position you will not be prompted to enter the PIN Code when
starting the device up and can change the code as you please
