Question about Sony Handycam DCR-TRV6 Mini DV Digital Camcorder
Sony dcr-trv6 beeps and shows c'
Have a sony dcr- trv6 mini dv camcoder. when i turn it on it beeps and shows c:31:30 on the lcd display screen. i tried a new battery,tapes, and keeping the door open for hours. and i use the reset button. it still does not work. HELP ME! thank you.
  • 169 Answers
Check the capstan motor if it is stuck up... find if there some debris inserted at the sensor...if nothing you find check also the bushing in the upper part of the motor
Posted on Aug 10, 2007
  • christian tope Aug 11, 2007
    if the motor running too past the capstan motor sensor is damage already...to be sure that is damage check if there a scratch on the sensor...if nothing you find check the resistance of the sensor about 200 ohms to 1 kilo ohms...
How to troubleshoot a video camera when the LCD screen is dark or has no display, in a Sony handycam DCR TRV22E mini
If you see correct picture in Eye Piece view finder but dark picture in LCD that shows problem with connecting flexible wire between LCD board and Camcorder main board. It got cracked/ damaged or broken after some time due to open/ close of LCD in its position.
Replace that flexible wire and problem will be solved.
Post back further question if you have any.
Thanks.
Dec 08, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony dcr-hc20e problem on screen in standby mode
my computer is unstalling all files and now my cd software to my sony dcr-hc20e digital video camera recorder was lost.pls help to find a free cd software to my sony dcr_hc20e digital video camera recorder
Mar 13, 2008 | Sony Digital Mini DV Pal Camcoder...
Sony dcr-trv6 unable to load tape in deck
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Aug 10, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony dcr-trv6 shows c:31:30 and beeps
the capstan motor of your camera is stuck up....check the capstan motor is there is some debris insert at the sensor...if nothing you find check also the bushing at the upper part of the motor....
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Trouble using dcr-trv6 mini dv camcorder
This is a common failure in this model and unfortunately will not be resolved without a qualified servicer. The error code indicates a message for lack of reel motion. Most often it is an electronic connection problem and not an actual reel problem. Good luck, magic seadog
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Sony Handycam DCR-TRV6 Mini DV Digital Camcorder Logo
116 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
