Question about Garden
How do I replace a clutch switch on a dixon 4516 mower
Dixon SpeedZTR 48 SE: When I want to start the blades, I pull the big red button. Now, nothing happens when I pull the red button
Probably an interlock switch is malfunctioning. Most common is the seat switch, but there are usually two or three interlock switches involved.
And it's also possible that the "big red button" or the electric clutch is bad. There's no way to tell without trouble shooting the wiring and components.
Is there an in-line fuse on this mower?
Aug 13, 2016 | Garden
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Dixon 5020 mowerhow do i install drive belt on 5020 dixon
If, and I'm sure it is, like all other riders, remove the deck, turn the mower up on it's side and supported with a lawn chair or the like, it won't hurt the mower, remove the electric deck drive unit from the crankshaft by taking the center bolt out and pull it off, remove the clutch tensioner far enough to get the belt off it, then remove the belt from the motor pully and the hydrostat drive pully and pull the belt out towards the front. replace the belt with new one and put it back together.
Oct 15, 2014 | Garden
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
Dixon ztr 46
unhook the pto safty swicth you might have to jump it or leave disconnetected see if that will help you need some more detail
Jul 04, 2013 | Garden
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
I need a left rear axle for a dixon mower it is bent so the chain jumps off, and a diagram of the rear assembly. It is blue with the levers between your legs, it has a 12hp motor. I am not sure what year...
You can eventually find your manual here:
http://www.dixon-ztr.com/node2171.aspx
There are a ton of manuals.... on that page. Looks like it will be a tedious hunt with out a model number.
If the link does not work go to
and click on support.
If you can come up with a part number you might be able to get it here:
http://www.lawnmowerpros.com/Dixon.htm
They also have parts manuals on this page:
http://www.lawnmowerpros.com/Dixon/Dixon-Parts-Diagrams.asp
Thanks for using FixYa.
Kelly
Mar 09, 2010 | Mtd LAWN MOWER PART # 903-0382 AXLE...
Mower dies when engaging .
most riding lawn mowers have a saftey switch under the seat. check there if it has one it is probably bad. A bad switch will most definately cause this
Apr 25, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
