Question about Krups XP2010 Espresso Machine & Coffee Maker
Krups repair manual
How to replace coffee maker power indicator light
SOURCE: Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Posted on Aug 21, 2008
  • 79 Answers
SOURCE: FME2 Coffee Maker
From page 9 of the manual:
Setting and Adjusting the Clock
• The machine must be “off“.
• Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink“ XX 88“.
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
Posted on Aug 28, 2008
SOURCE: handle came loose on Krups carafe
Easy fix. Pry off the cover on the handle to expose two philips screws. Secure the screws back in and pop the cover back on.
Posted on Sep 14, 2009
  • 22 Answers
SOURCE: A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Jan 31, 2010
sandrineFY
  • 268 Answers
SOURCE: Dear Sir!
Check on the Krups site:
http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm
Posted on May 28, 2010
No power no light
check cord for damage, while plugged try wiggling wire in different locations and watch for power, if you see power replace cord, if no power replace machine
press the helpful button and check links below
Drip Coffee Maker Problems HowStuffWorks
How to Repair Coffee Maker How to Repair Small Appliances Tips and...
Coffee Maker Repair How to Repair Small Appliances
Jan 30, 2016 | Coffee Makers & Espresso Machines
Coffee maker not brewing after changing water filter
Dis asselble the coffee maker and make sure there arent any coffee grinds stuck in the grinder, this is the usuall problem to coffee makers after some time.
Apr 29, 2008 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Why does the power light keep blinking
The blinking light is wrongfully indicating that there is not enough water in the tank. The sensor is a small magnet that is floating in a compartment at the bottom of the water tank. (The black square in the corner) You shold be able to see it. Check if it is stuck at the bottom and if it is floating in its chamber. If that is OK, the sensor inside the coffee maker that is reading the magnet might either have come faulty or dispaced (due to a shock?). That would need a disasembly of the coffee maker.
Villi
Jul 05, 2014 | Philips Senseo HD7820 Espresso Machine
Need a replacment Carafe for a Gevalia CM500 Coffee Maker
www.ebay.com
In the EBay Search box, paste in: Carafe for a Gevalia CM500 Coffee Maker
You'll find several for sale
Mar 30, 2017 | Coffee Makers & Espresso Machines
It wont turn on
If power at wall is OK, then the circuit board and pad indicators are defecetive. Return for exchange.
May 11, 2012 | Keurig B60 Coffee Maker
I got this coffee maker from a friend with no instructions, i have no idea how to use it. I am not interested in grinding my own beans, i just need to know about where to put the filter and so on.
Use it by plug the AC cord so it has gets electric power and switch on the power button it should light indicate there is power. Put the filter on its container but twist the elevated cup carefully on right or infront, that the container where you put grinded coffee bean powder. It is where the hot water drips on coffee beans down the glass hot container where drip coffee collected.
That's it I hope I explain it clearly and solve your problem.
Mar 29, 2011 | Krups Fresh Aroma 619 Coffee Maker
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Bunn coffee maker not working
My warm indicator light is not working. Only used less than a month.
Nov 15, 2007 | Bunn NHB Coffee Maker
Krups XP2010 Espresso Machine & Coffee Maker Logo
88 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
