Question about Samsung SRP 350 Thermal Printer
Addmonitor error code 1805 - Samsung SRP 350 Thermal Printer
P1801 and p1806 codes come up is there a easy fix 2000 accent
P1801:------- Immobilizer Transponder Error. ------------------------------ P1805/P1806:----- EEPROM Error/VIN Mismatch. ------------- In most cases the error 1801 and 1805 comes up together.But error 1806 is very rare.But 1806 and 1805 both are error related to same problem. P1801 and P1805/06 are immobilizer errors. Does your car have an anti-theft
device which reads a transponder in the key? If so, the problem is with
this system. T
he immobilizer problems are typically with the
lock cylinder sensor. --------------- Keep updated with further queries if required.Thanks.
Oct 19, 2010 | 2000 Hyundai Accent
My laptop wont boot up. it only goes to the IBM screen and on the top it says error 1805 turn off and remove pci card. and if i go intothe diagnostic boot it says internal pci card shadowed and also says...
The POST error code 1805 for the ThinkPad is as follows :-
1805
Unauthorized Wireless USB card is plugged in—Power off and remove the Wireless USB card.
  1. Remove the Wireless USB card that you installed.
  2. System board.
Please click on this link for further POST error codes and explainations
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=ibm&lndocid=MIGR-42321&velxr-layout=print
Jul 03, 2010 | IBM ThinkPad T30 2366 Notebook
Adobe Photoshop CS2 autorization code
If your serial is 1045-1083-6395-0392-3604-2837 (I got this one from your profile) and a act 0579 - 1545 - 1800 - 8483 - 3649 - 1805 - 4745 then your auth code is\
5183 4466 9314 7205 7233
please gimme a comment if that works
Thanks
Jun 18, 2010 | Adobe Photoshop CS2 for PC
All the lights are flashing on Asko 1805 dishwasher
Hi, You need to absorb the water in the overflow basen of the Asko dishwasher's and then push and hold a button to reset the error code...flashing LED's or turn the power off momentarily. You need to remove the lower kick plate and get to the basin with a wet-dry vacuum or sponge etc. Good luck. Let me know if I can assist you further. Thanks for visiting fixya and if you found this solution helpful please rate it accordingly. Macmarkus :)
Apr 08, 2010 | Asko 24 in. 1805 Built-in Dishwasher
Hyundai Matrix will not start when damp EOBD codes P-1801 and P-1805
Yes... it's the immobilizer system p1805: Inconsistent data of EEPROM Invalid write operation to EEPROM Not plausible immobilizer indicator stored in the ECM No valid data from SMARTRA after 3 attempts by ECM Invalid tester message or unexpected requests by testerGo to http://www.hmaservice.com/ and register. You'll have access to lots of info (technical and otherwise) about your vehicle.
May 27, 2009 | Hyundai Motor 2004 Accent
Toshiba 1805 new optiarc ad7560a dvd drive change to slave
at the back of the drive there should be some pins with platic removeable pieces,most times it will tell you which pins are slave or master and have a diagram on the case of the drive etc,make sure they are set to slave.
Mar 12, 2009 | Toshiba Satellite 1805-S204 Notebook
Cd for Toshiba Satellite 1805
ok..when turning it on..hold down F2. to go to set up..and see if that new drive is activated..be careful in there..there are loads of things that can go haywire.
Oct 16, 2008 | Toshiba Satellite 1805-S204 Notebook
Boot volume error
A stop error indicating UNMOUNTABLE_BOOT_VOLUME is nearly always symptomatic of a hard drive that has died. Take your PC to a local technician to be serviced.
Jun 12, 2008 | Toshiba Satellite 1805-S204 Notebook
DVDM 1805
it sounds like you might need to clean the laser eye, try that and get back with me
Dec 10, 2007 | Denon DVM-1805 DVD Player
Samsung SRP 350 Thermal Printer Logo
55 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
