I have a 42" FHD LED TV model No. BLED42FHDAE connected by HDMI cable to my set top box, I have to use the Bush remote for volume control and the virgin remote to change channels. Can I get volume control onto the virgin remote? Help please. Betty
SOURCE: set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Posted on Apr 22, 2008
MNfisherman
  • 11896 Answers
SOURCE: HDMI issues with Comcast HD Box
HDMI Has a safety feature that blocks other remotes from changing things. What a Joke I say. There could be a problem with the feature.
You can push up on the "Settings" button on the remote twice to enter the "advanced" settings menu. There might be something in there that needs to be set.
I found out that if I change the cable box output from HDMI to DVI it will work fine but the picture is not as clear.
I believe its a hdmi and communication problem with you box.The only thing you can do is to go back to component video cables until they come up with a fix.
Posted on Jan 17, 2009
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
macgroovy2
  • 52 Answers
SOURCE: Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Posted on Jun 18, 2009
SOURCE: virgin media remote control TV Control Codes Samsung LE37A558
just tried 0079 from another forum and it's worked for me!
Posted on Mar 30, 2010
Need code for my remote control for my Bush Tv
Codes are in the remote. Finding the code depends upon knowing the "brand" of remote and whether it is universal (URC-???).
Feb 01, 2016 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
Bush bled42fhdae led tv colour calibration is wrong,emphasizes majenta too much
White balance maladjusted. Adjust it properly. If you wish to get some details; visit the site linked here. Pull up older posts.
Aug 11, 2017 | Televison & Video
The picture is too large for screen and is cut off on top and bottom. Possibly on the sides too.
There is a button the remote control that will resize images. However this could also indicate that a tv is in the wrong input and or connected to the set top box (ie cable box or satellite receiver) incorrectly. It can also indicate that the set top box is set to the wrong resolution.
Buttons on the remote control could be view mode, aspect or format, and # hd zoom.
The tv could be in the input for the rf connector or the composite cables instead of being on the input for the component or hdmi cables.
The tv could be connected to the set top box with RCA cables or a coax cable instead of being connected with component or an hdmi cable.
Apr 28, 2010 | Televison & Video
Connect the hdmi out put of a bush hd set top box
its telling you that you cant use the format that your source is set up for .. like 1080P wont play on a monitor that wont support that ..also hdmi requires an exchange of information between units before it will allow 1080 resolution (thats to prevent recording of high resolution material) the adapter may block that exchange .. if you set the source to 720 or less resolution then its likely to start working .. problem is .. if you cant see it how do you set it .. if your remote has an obvious button for that then you can just try selecting different modes and wait 10 seconds to see if it works .. if its not obvious then perhaps you can temporarily use svideo or composite in order to set up the source machine ..
Jan 27, 2010 | Televison & Video
JVC LT-Z37SX5 no sound when using hdmi connection to HD box
the tv has a configaration that conveys the sets focus on both audio and video performance. full hd resolution of 1920-1080 pixels.
hdmi inputs allow connection of the generation of 1080p sources for the systems which offer 1080p outputs
Jan 12, 2009 | JVC AV-36D303 36" TV
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Poor signal bush hd set top box
I have a saterllite reciver just bought a bush hd freesat top box i am running my virgin cable tv through my samsung hd television i put my satallite cable in to my bush top box connect the hdmi cable to get the freesat turn my virgin box off source the hdmi cable on tv get the freesat logo but nothing else what am i doing wrong
Aug 31, 2008 | Televison & Video
HDMI Cable problem
Well, first you might want to try another hdmi connection behind your TV.If it appears to have the same message,you need to check your TV setup and be sure the HDMI video is active.
Secondly,go with the recommendation of the set top box.You will use component video cable to connect from your set top box component video output(Y PR PB) to your TV (Y PR PB) and see if that actually work.If so,just use the cable box for the time being and call your cable company for another cable box to replace this one!
solutiondoct
Jun 13, 2008 | Samsung HP-T4254 42 in. Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
