Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen shrinks to 10 cm horizontal line
Hi to all, i have the model listed above, my problem is that the screen shrinks to 10 cm horizontal line usually after turning on 4 a while but it can occur suddenly, if the tv shuts off for a while it will pass and work normally. i think it may be linked to the vertical spreading Amp.. any help will be wellcomed.
  • 398 Answers
Yes, you are correct. Usually what I find in a set like that with that symptom is that the solder joints have cracked and come loose on the vertical output IC. That is the IC which drives the yoke coils that spread the picture up and down. If you have soldering experience then you can locate this IC and resolder its pins but if you have never worked on PC boards then have a qualified tech handle it for you. This is a very easy thing to repair so it should not cost too much.
Posted on Aug 07, 2007
SOURCE:
Picture cut off on sides, how do i shrink picture to screen?
If model listed is correct the problem is in power supply or vertical or horizontal circuits.
If cut off on sides (horizontal) and bowed on sides it is a pincussion problem. IF short top and bottom a vertical issue--if both it is in the power supply.
Model listed is rather old and parts may not be available for it.
May 30, 2012 | GE 35GT740 35" TV
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
The shrinked screen with two white vertical line in the middle
B+ line going hi.
probably bad capacitor on hot's collector.
could also be leaky dual diode.
if non of above, look for swollen cap on main board.
Jul 12, 2008 | LG Studioworks 700S 17" CRT Monitor
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
TV - Thin horizontal line picture on screen
Is this a LCD TV? IF it is it could be something on the video processing board. Let me know the model # and well will go from there. Thank you Jay
Jan 31, 2008 | Televison & Video
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
