I had a problem with choosing songs form list so I thought to format the drive. After I formatted the RCA Lyra RD2317 and I put songs on it. When I try to turn it on it doesn?t work. Then again I connected the drive with computer and format again. It used to have four folders when I connected with computer but now it doesn?t have it. Can anybody tell me how to fix this problem???
Remember when you format memory like a hard drive you erase everything. Move music to your internal mp3 memory and do a profile - folders should appear.
If you have flashed your player with the firmware update you can get 520 songs on the player for both internal and external combined but be warned that if you exceed this count your player will start to forget the earlier loaded songs - listed but not addressable (playable). The same is for the folder count eg. add album = artist + ablum title (min 2 folders). Plus always profile your songs after loading new music or deleting as this is an index build process to play song 152 = title x. This includes accidental radio recordings to MP3s.
RD2312 , RD2315, RD2317 Lyra™ mp3 flash player Firmware/Application Upgrade Version 3.11 fixes:
Supports a total of 520 songs, in up to 50 folders, with up to 8 levels of subfolders.
The service is completely free and covers almost anything you can think of (from cars to computers, handyman, and even drones). click here to download the app (for users in the US for now) and get all the help you need. Good luck!
MP3 players can only play music files in mp3 file format.
You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player. You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format:-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
What i do is i never put songs in my internal memory...this way you never have to worry about formating the internal memory....so i have several exteral card i use say one for country or rock and its so easy to format a exteral card just place it in ur card reader if ur using a laptop them go to my computer right click on ur card that youll find then youll notice on the list theres format so its so easy...im sure its asking you to format ur drive because you must have a few corrupted files....best of all when adding music just pull ur external card out place it in a reader fill ur card with music then insert it back in ur device...this way ur getting away with using any firmware....by the way take any disc that came with ur Lyra and chuck it in the garbage that 90 percent of all ur problems
This player can only handle songs that are in a specific bit rate - lower it to the rate suggested in your product specs. Go to RCA's website if you have lost the documentation. Corrupt file systems can usually be solved with a firmware upgrade (also at RCA's website), but if that fails: There are two ways to format an Mp3 player - one on the computer
itself, and one in Windows Media Player. Both methods will end up
erasing all the songs on the player, but the player will be "good as
new" after that. Sometimes reformatting in this manner will override
the player's native formatting and cause problems - this can be
reversed in most cases by updating the player's firmware. Firmware
upgrades are available from most manufacturers' websites. WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or
FAT32. - Connect player to computer, double-click my computer, right
click on icon of mp3 player and select format. This only applies to
Windows-based computers. You can also format the player in Windows Media Player itself: Connect your Mp3 player to the computer and open Windows Media
Player. Click on the Sync tab. Pull down the drop down menu underneath
the Sync tab by moving your cursor over the Sync tab and left clicking
on the little black arrow underneath the Sync tab. Highlight "name of
Mp3 player here 1GB" (wording may vary slightly), and then select
"Format." - this should erase everything. -Tha Mp3 Doctor
My suggestion is switching the file transfer protocol from MTP to MSC by accessing it under the Menu.
Once you do this, when the Lyra is plugged into the computer, it will appear as an external hard drive.
Format the hard drive and then drag and drop your songs and/or directories of songs onto the Lyra.
This is what I do, as I never use Rhapsody, URGE, or even Windows Media Player or MusicMatch to upload songs onto my RD2763.
Hope this helps!
I had the same thing happen to my Lyra tc1001a.
to fix it I had to go to the command prompt and format the drive C:\format G:
this does erase everything on your lyra though hope you have your songs backed up...
BW
I had the same problem, and that is what RCA answer me:
Due to a unique FAT12/16 cluster size requirement, the supplied format utility that comes with the RD1021/RD1071/RD1075 MUST BE used on all SD/MMC cards before they will work in the RD1021/RD1071/RD1075. Once formatted, these cards will still be FAT compatible and should still work with other devices, i.e. RD1080. The format utility can be found under "Programs", "Lyra Personal Audio Player", "RD1021,RD1071,RD1075", "Format Media" once your software has been correctly installed from the included RCA CD-ROM.
