Question about Exercise & Fitness
Technofit Instructions?!
Technofit ts500I treadmill When its running the treadmill starts and runs fine. However when I get on it, it the speed becomes jerky running slow fast slow fast making it impossible to use.
If someone spilled a drink on the belt, it will become sticky as it dries. The belt will try to stick to the bed of the treadmill. Loosen belt, wipe clean the bed, underside of belt, and end rollers.
Apr 24, 2014 | Exercise & Fitness
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
My Technofit TS500i Treadmill has just stopped working the computer is still working fine but the belt has stopped rotating
I have a technofit ts500i with a broken computer but the motor and treadmill still work. would you consider selling your computer consol only
Aug 15, 2010 | Exercise & Fitness
Help Please ASAP. NEED Assembly Instructions
lbehrman
Here is the instructions on their site.
http://www.woodcrestmfg.com/instructions/instructions.htm
Hope this helps
Issken
http://www.fixya.com/users/issken
May 08, 2010 | Baby Gear
Instructions for Nordic Ware Microwave waffle
I have a Nordic Ware microwave waffle iron and cannot find the instructions. The instructions on the waffle iron are ok untill it says see instructions. (Which I do not have). Anyone out there have the instructions and can scan them and e mail them to me at vdanziger@gmail.com thank you
Apr 04, 2010 | Kitchen Appliances - Others
I can't remember how to put my carseats harness back together
The manufacturer's instructions are the final authority - don't trust anyone else giving you instructions! Here are the links to download Cosco carseat instructions:
Canada:
http://www.coscojuvenile.com/can/eng/instructions
USA:
http://www.coscojuvenile.com/usa/eng/Instructions
Jul 04, 2009 | Cosco Juvenile Scenera Convertible Car...
Breadmaker TR520: Page 5 instructions, #4 says "Before first use, operate Bread maker on FAST BAKE to burn off mfg oils. Follow instructions outlined in the OPERATIONG INSTRUCTIONS section of this...
I ignored the instructions which told me to follow instructions which were left out of the booklet. I just washed the breadpan and paddle with hot water and dish detergent, dried them, and made bread. Everything A-OK.
Sep 12, 2008 | Breadman TR500 Bread Maker
Programming problem
Program flow control structures obey ceratin rules. They start with a keyword and end with another keyword
For
Instructions
EndFor
If .....Then
Instructions
Endif
If .....Then
Instructions
Else
Instructions
Endif
If..... Then
instructions
ElseIf......Then
instructions
Else
instructions
Endif
Loop
Instructions
Endloop
While
Instructions
EndWhile
Each ot these structures is called a block. If one of the keys words is missing, the program generates a syntax error.
Hope it helps.
Feb 25, 2008 | Texas Instruments TI-89 Calculator
Exercise & Fitness Logo
44 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
