Question about Toys
How do you bind a Saturn 2.4ghz six channel - Toys
2009 Saturn aura idles high after cleaning throttle body. Anyone know how to fix this?
Check vacuum hoses are all fitted , check the throttle body butterfly has closed fully on its stop setting and no cables are binding.
Jan 05, 2016 | 2009 Saturn Aura XR
2007 Saturn ion wont idle down
Your vehicle has drive by wire or electronic throttle control ! It has a 12 volt electric motor that opens an closes the throttle plate ! You need to have it check for DTC'S diagnostic trouble codes ! an checked for binding throttle plate !
May 26, 2015 | 2007 Saturn Ion
I am trying to bridge two macrotechs 1200 and I am getting a loud huming noise . No sound. Just that noise. When I run them in stereo mode they work perfectly fine. What causes that?
Let's review the setup procedure and precautions. This is for bridging the amplifiers within a single box.
  • The mono-stereo-bridge switch must be in bridge position
  • The input signal must be connected only to Channel 1. NOTHING should be connected to Channel 2.
  • The Channel 2 level control should be turned all the way down. Turning it up will amplify common-mode noise.
  • The + speaker terminal is connected to the red binding post for Channel 1 and the - speaker terminal is connected to the red binding post for Channel 2. Neither side of the load should be grounded.
  • There are no connections to the black binding posts. They should not be grounded or shorted together.
It does not seem practical to bridge or parallel two MT 1200 boxes; it would be very difficult to get the levels and offsets precisely matched. If they aren't matched, you will get oscillations or common-mode amplification - that is your humming noise.The bridging switch makes six changes to the circuitry to get the amplifiers properly interconnected in one box so this won't happen in the recommended configuration.
Jun 20, 2011 | Crown MT 1200 2-Channel Amplifier
Fusses on channel five and six blown can't read the rating any ides????
If the fuses on the other channels are good, try replacing the bad ones with that type and rating (assuming there are fuses on the other channels). My experiance suggest they should all be the same, as they are dealing with the same power levels roughly.
May 21, 2010 | Niles SI-1230 12-Channel Amplifier
Do the ride viper contrabands fit on the new burton boards using the channel system or the retro fit system for the new burton boards
They wont fit directly as Ride bindings are made of very lite metal and need all four screws to stay secure. The best idea is to buy the matching Burton binding or avoid the channel system and stick with 4 x 4 brands
Apr 23, 2010 | Viper Ride Contraband Snowboard Bindings
When I turn on my Philips lx8500w dvd player my wireless internet stops working, what may be the problem?
the lx8500w uses the same frequency as the wireless (2,4Ghz). I bought the same system, it's ********. Just problems and after 2 years it doesn't work anymore (goes to standby after 1 hour or so). Try to change the wireless channel. Or buy another home cinema...
Mar 19, 2010 | Philips Home Cinema system DivX LX8500...
Panasonic KXTG2344 Phone 2,4ghz malfunction with microwave
You can change the channel used by the phone in the settings, but the better option is to make sure the charger base is nowhere near the microware.
Also, make sure that the microwave and the charger base are NOT plugged into the same outlet. I would even try a different outlet than you are using now as interference would definitely pass through the line.
Dec 02, 2009 | Panasonic KXTG2344 Cordless Phone
The same Problem on Windows 98...
Your soundblaster driver may be corrupted. go to creative website, search for your sound card, and find download for driver.
Aug 23, 2009 | Intel Premier Resources 4-Channel 32-Bit...
What are the steps in changing spark plugs on a 2002 saturn vue six cylinder suv
I think you bought the dreaded Opel v6 in your Saturn. If it has six rubber hoses on the intake tubes, thats the Opel. A couple of years later, Saturn started using Honda v6's. A royal pain to replace the plugs, suggest a repair shop because the intake has to come off.
Mar 26, 2009 | 2002 Saturn VUE
Power Window
Lube the window channels and regulator
Nov 18, 2008 | 1998 Saturn SL
Toys Logo
29 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
