HOW DO YOU CHANGE THE BIT ON A 99186 WILTON ROUTER
Does anyone have Wilton elephant cake pan instructions
The pan style has been discontinued but you can still download a copy of the instructions in PDF right here: http://demandware.edgesuite.net/aawa_prd/on/demandware.static/-/Sites-wilton-Library/default/dw76d09c81/paninstructions/2105-0576-ElephantPan.pdf http://demandware.edgesuite.net/aawa_prd/on/demandware.static/-/Sites-wilton-Library/default/dw76d09c81/paninstructions/2105-0576-ElephantPan.pdf
Sep 01, 2017 | Baking
Wilton planer 99178
Walter Meier took over the parts division of Wilton, they are based in Europe. The website is not up to speed.
Dec 10, 2013 | Tools & Hardware - Others
Where can I get a cookie press? My old one just broke after 25 years of using it.
If you are looking for a very simple cookie press, you could try amazon; http://www.amazon.com/Wilton-Cookie-Pro-Ultra-Press/dp/B000I4OJ1E/ref=pd_sim_k_1
But if you want to replace your broken one with something a bit sturdier, take a look at this link:
http://www.wilton.com/store/site/product.cfm?sku=2104-4018
Feb 28, 2013 | Baking
Where can i get the stem part for the wilton multipurpose vise model # 69999
Hi, W/D here.
Here's a link to Wilton Vises at McMaster/Carr. In the middle of that page is a link to the repair parts. I am sending the first link as the second link is a download, and I could not link the link to this post. One extra click, friend. Best I could do. If you get the part number from the parts sheet, you could continue to shop around and maybe find it cheaper, but I doubt that there are many places stocking such parts. McMaster prices are pretty good in my experience, and a phone call to them will get any answer you need. Good folks. We have spent mega dollars with them as a one stop source for many industrial needs. Huge catalog, if you're interested. Great reference book.
http://www.mcmaster.com/#wilton-vises/=badoze
Best regards, --W/D--
Mar 04, 2011 | Wilton Multipurpose Vise 5in., Model#...
17202 8'' bench grinder 3yrs old hasent run 1 hr needs on off switch wilton stated after 6mos of waiting for soposed back order that co that maid these for wilton is out of business they said try lowe;s...
go to your local marina and buy a simple on off switch or take the wires off the switch on your grinder and hook them up to a extension cord and put an inline light switch on the cord.
Oct 21, 2010 | Wilton 17202 8" Bench Grinder
Saw blade jumpes off at motor pulley on horizontal band saw
It is probably not tracking. you need to back off the guides, get the blade to track in the center of the tire by hand. Then torque it up a bit till it twangs, Then pull the guides up the blade and just touch it, don't push it at all, the bearings too. This should track and not jump off. If it does, then one of your wheels is out of whack, check them with a straight edge with the blade set. See if they are in line. One of the bearings could be bad. Check it out.
Apr 15, 2010 | Wilton 5" X 8" Dry Horizontal Bandsaw Band...
Blade comes off wheel on horizontal saw have a wilton 7040 horizontal saw. after cutting about 1/2 thrru a piece of metal the blade sticks and then stars comming off the right wheel and starts cutting into...
if its a new blade, make sure that it is the proper length for the saw, sometimes aftermarket blades look like they are the right size but the difference of a few mm can cause the blade to track. if its an old blade, it could just be dull enough that it is binding on the material you are cutting and this draws the blade off the wheels. even if the blade isnt that old or seems sharp, if you have a brand new blade handy that would be the easiest thing to try.
your manual will have instructions on how to adjust the blade guide bearings. if this is a new saw, it SHOULD be set properly and be working from the factory but they may still need to be adjusted. an older saw obviously may have shifted a bit from normal usage. if you dont have a manual one can be downloaded from the wilton tools website.
before adjusting the guides, though, check to see that the bearings spin freely. if they do not spin smoothly with minimum pressure, they need to be replaced. they also should be replaced if they spin VERY freely because this is also an indication that they are pretty worn and may actually be binding up under pressure.
Dec 02, 2009 | Wilton Saws
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
