Question about Dometic RM2852 Refrigerator
Dometic rm 183
Dometic rm183 works on propane but flame is very weak. it's old but are parts available yet?
    Top Expert:
  • Dometic Master
  • 5,743 Answers
Check gas pressure if ok clean lines to ignitor and blow out orfices
Posted on May 30, 2016
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 93 Answers
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
  • 3 Answers
SOURCE: I have a Dometic 2193 3 way fridge. It works
The flue baffle was the solution that worked for me as well. Below is a response I posted to a similar post.
I had a similar problem. The flue would get hot and the cooling tubes would get "warm". The refrig would get a LITTLE cool but nothing to be of any help.
I solved it though...it turns out there is a "flue baffle" (twisty little metal thing) that is supposed to hang in the inside of the baffle. It hangs from a screw found on top of the baffle and it is supposed to hang down.
The screw that held mine was corroded and flue baffle had fallen into the baffle and landed on top of the burner.
I ended up fishing the flue baffle out of the top of the baffle with a coat hanger, then rehanging it using a new screw. That solved my problem.
Not sure if this will work for you or not but good luck.
By the way, you can find an owner's manual with a diagram showing the flue, the flue baffle, and the piece of metal holding it here:
http://www.fourwheelcampers.com/DometicRefrigerator.pdf
Look on p.9, figure 9. Item C is the flue baffle and the wire holding it. Item B is the screw that was corroded on mine, and ended up dropping the baffle down to the bottom of the flue.
Below is a link to some generic directions on solving fridge-related problems. I found it to be VERY useful.
http://rvmobile.com/Tech/Technical.htm
Posted on Jul 28, 2010
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Mar 28, 2014 | Dometic RM2652 Refrigerator
Rm 183
Check across and dc if there is no sign of controls working. If the power is there and it is not cooling you will need to verify if the heating elements are getting hot and/or there is operation of the l.p. system with a flame presence. If you have a flame and the elements are getting hot then you have a bad cooling unit. If they are not working, either one, and you have good power then you more than likely have a bad control board.
Mar 17, 2014 | Dometic RM2852 Refrigerator
I bought at Dometic propane/ electric fridge for my cabin last year. It has not run properly since. The fridge will light and run for a while with a blue flame but sometimes in the idle mode it goes out....
I have to ask, what is idle mode? I've never seen one that runs on idle mode, in a RV in 15 years. Has anyone used a manometer and tested Inches of water column in propane supply to fridge, as well as other appliances?
Any I've seen run on propane, are either on, (flame present, or off, no flame present.) Flame goes out completely when not calling for cool.
Jun 13, 2010 | Dometic RM2620 Refrigerator
I have a mid 70's Dometic RM 211 refrigerator in my camper. The screen on the propane burner has been damaged and needs to be replaced. Parts no longer exist from Dometic. What size wire mesh do you...
Hi Brian,
You don't want to use a screen that is made to fit. The original part was designed for a specific flame. That being said, colaws rv salvage may have a replacement burner in stock, and you can also try calling up a company that rebuilds cooling units for rv fridges.
Jun 03, 2010 | Dometic RM2193 Compact Refrigerator With...
Dometic rm 2620 fridge problem
The flame is not hot enough check gas pressure
Jun 22, 2009 | Dometic RM2620 Refrigerator
May 18, 2009 | Dometic RM2620 Refrigerator
No propane
Yes it can also run on 120 AC and 12 volt DC
Here is the website. If you need help in understanding let me know
http://www.campingworld.com/shopping/item/dometic-rm2193-compact-refrigerator/13473
Apr 21, 2009 | Dometic WA3210 Compact Refrigerator
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic RM2852 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
