Question about Canon PowerShot SD600 Digital Camera
Lens Retraction I've had my PowerShot for seven months and yesterday, after taking a picture, my friend turned the camera off and the lens structure did not retract nor did the cover go over the lens. When I turn it on now, it says "Lens error. Restart camera." but it won't seem to fix itself. What should I do?
  • akkf Nov 07, 2007
    i have a cannon sd630 the lens will not retract, on screen message is lens error restart camera. i did that about 20 times.. still not retracting, help if you can... thank you
    [email protected]
  • 641 Answers
Since your camera should be still under warranty, best thing will be to conntact to the appropriate factory service center for correction of the problem. Good luck!
Posted on Aug 07, 2007
  • Dov Dror Aug 15, 2007
    Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem.
    In any case it could not make it worse
    Ohlala,
    it will nice if you will participate us with the way you solved your problem !
SOURCE:
Lens retraction noise in canon powershot pro 1
The lens needs to be dismantled, cleaned and lubricated by a camera specialist, the alternative is a lens that will eventually seize, shutting down the camera.
Apr 08, 2012 | Canon PowerShot Pro1 Digital Camera
Lens error restart camera
your cam is out off order
if want it back needs to replace optical block
assembly that is the only way.
good luck..
Feb 26, 2010 | Canon PowerShot A590 IS Digital Camera
About 2-3 months ago my camera suddenly said lens
If it says lens error all you have to do is try pushing the lens back in. If that doesnt work, sorry! lol =(
Oct 10, 2009 | Canon PowerShot A710 IS Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
Lens error,restart camera
Jul 03, 2009 | Canon PowerShot A460 Digital Camera
Lens error, restart camera
Apr 26, 2009 | Canon PowerShot SX100 IS Digital Camera
Error 18 Lens retraction problem
The lens mech has been damaged (likely by being dropped or bumped). If it is not VISIBLY crooked or twisted, odds are that you have a broken gear or other internal. The only fix is a new lens assembly, which tends to be rather expensive ($80-$200), just for the part.
Please rate this solution.
Aug 30, 2008 | Canon PowerShot S2 IS Digital Camera
E 18 Message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 21, 2008 | Canon PowerShot S2 IS Digital Camera
Lens Movement (Retraction)
Sounds like you might have bumped the lens. In for repair is your best bet
Oct 25, 2007 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
540 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
