Question about Troy Garden
Model J609 troy bilt riding mower transmission won't engage?
4 Suggested Answers
  • 18 Answers
SOURCE: troy built riding mower runs at low speed and
Probably an engine problem.
Does it run at max rpm with mower deck disengaged?
Posted on Apr 18, 2010
  • 97 Answers
SOURCE: Need an Owners Manual for
http://manuals.mtdproducts.com/mtd/Safety.do?pid=219561&model_num=13AN779G766&serial_num=&filename=769-01543.pdf
If you search on the MTD products website for any other manuals for this model, use 13AN779G766 as the model number and don't enter a serial number. Their online owners manual system is touch and go.
Posted on Sep 01, 2011
  • 6468 Answers
SOURCE: Problem with Troy Bilt Mower Pony model 13AN77K011 . New Battery. No Power. Won't Crank.
check the safety switch on the clutch/brake pedal
Posted on Jul 19, 2012
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy bilt zero turn mower runs but does not move
Make sure the gears are engaged. There are 2 metal hooks on the rear of the mower, 1 on each side, if they are pulled out the mower is out of gear, make sure to slide them over so they retract back into the mower. If not the problem, sounds like either broken drive belts or the transmission isn't working properly.
Jul 02, 2014 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
Troy-bilt model 13AN77TG766 wont go forward or backward. Belts seem to be moving fine. Please help, unable to find manual online.
The manual probably won't be of much help with this problem. Your transaxle may have seized up or failed due to the introduction of water into it. A lot of riders have had this problem, especially the ones with the DANA manufactured transaxle. I hope this is not your problem, and that the problem is in your shifter linkage between the lever and the transmission.
I am continuing to look for the manual. In the meanwhile, here is your complete machine with All parts, diagrams, breakdowns and part costs included. Hope this helps. It is sometimes tough to locate manuals as you have found.
http://www.partstree.com/parts/?lc=Troy-Bilt&mn=13AN77TG766+Pony+%282006%29
May 21, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
How maintenance Troy bilt, 6.50 190cc 21" 2 in 1 push mulch mower with rear bag?
my troy-bilt 21" mulch mower 6.50hp/190cc won't start after it run for any amount time.
Sep 05, 2010 | Garden
I have an early-2000s Troy Bilt Bronco, 42 inch deck, 18hp Briggs Inotek engine, hydrostatic drive. It broke or threw a drive belt (not for the mower deck, but a transmission belt). How to you go about...
While mowing the yard, the mower went dead. I tried to recrank it and it won't crank. The gas pedal goes straight to the floor and doesn't work to crank the mower. I do not know anything about mowers and don't know where the problem could be. Can someone help?
Jun 14, 2010 | Troy Garden
Garden Logo
24 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
