Question about Technics SA-AX540 Receiver
Technics sa-g78 no sound from front speakers
Hi all, I have a Technics SA-G78 receiver from a friend, but there is no sound from the front right and left speakers. all other speakers and the subwoofer work...any answers as to how to fix this? Is there a fuse I can replace?
  • Anonymous Mar 31, 2008
    have same problem, just happened... any known repairs?
  • jag6670 Apr 03, 2009
    I have no sound on the right speaker A or B
    everything else is perfect
This happens on mine also. My theory is a relay. If you turn the volume up (Waaay up) momentarily, you "burn through" the oxidation on the relay and the sound comes back - for awhile. Some day, I'll get in there and replace it with something more robust.
Posted on Sep 30, 2008
Buy yourself a nice Krell amp!!
Posted on Jun 25, 2009
How do i fix fault g78 and g289
3 - Left Front Level Control System Sensor -G78- and Right Front Level Control Sensor -G289-
May 24, 2014 | 2009 Volkswagen Passat 2.0T
Right side no sound to speakers
The output transisters for that side are probally blowin,
Dec 06, 2012 | Technics SA-EX110 Receiver
I have a Technics AV control stereo receiver sa-g78 Whenever I turn it up a little louder than normal..is says overload then it powers off...I need someone to tell me what I need to do...but dumb it down...
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 28, 2011 | Technics Audio Players & Recorders
When I turn on my technics sa-gx amplifier I can't hear the sound
Have you noticed if the speakers selector switch in the front panel is set to off ? That position for the switch is only suited to listen heaphones. Good Luck.
Flavio/BRAZIL
Jul 28, 2010 | Technics SA-DX750 Receiver
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
Technics SA-DX930 Sound cutting in and out
try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
May 19, 2009 | Technics SA-DX930 Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
I need help
Loose connection on "POWER-SUPPLY" and sometimes solder loose on "C I S BOARD" due to extreme - heat of amplifier. $137.51 repair done in 1HR as I waited at CENTURY SOUND ELECTRONICS.
Jan 19, 2008 | Audio Players & Recorders
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
Technics SA-AX540 Receiver Logo
940 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
