Question about HEALTHRIDER R60 SoftStrider Treadmill
Healthrider what size hex key do I use? I got the treadmill and it didn't have a hex key.
5 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: healthrider r60 stops when it reaches 4mph.
Unplug unit and remove the motor shroud you will have to do DC Amp Measurement.
Measure on the hot DC lead (usually red) going from the controller to the drive motor. If you have a simple multi-meter with a DC amp test setting the best way to test is to put the meter inline on the red motor lead with alligator clips. If you have a more expensive clamp meter, clamp the meter around the red motor wire. Run the machine at 2.5 MPH without a person on the belt. If the motor and drive system are healthy, you should have a reading in the 2-3 amp range. Then walk on the treadmill at the same speed. With a person of average size (around 200 lbs.) you should have a reading in the 6-8 amp range if the belt is good. The readings will fluctuate more with a load but you are looking for an average reading but you shouldn't see spikes above 10 amps. If the amp readings are high without a load, you could have a problem with high resistance in the motor, a bad bearing, or over-tightened belts. Regular readings without a load but high readings with a load indicate a worn belt and/or deck.
Posted on Jun 28, 2010
Andriod Man
  • 271 Answers
SOURCE: I have a HealthRider S300i
you can try to rent a set at AutoZone. when you return it they will give your money back. try standard and metric. depending on manufacturer of treadmill.
Posted on Feb 09, 2011
ercupa190
  • 12223 Answers
SOURCE: my healthrider s300i softstrider treadmill
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Posted on Dec 13, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a Healthrider Softstrider
1) you have 3 problems: mechanical+ electrical + electronic.
2) adjust the tensions from deck bel + drive belt motor
3)test the main motor without load and see what happen.
4)test the main motor board and see what happen.
see block diagram
How do you check actual mileage on a Healthrider r60 treadmill?
I dont believe it is possible. Not many brands worldwide give you this option.
Jan 02, 2013 | HEALTHRIDER R60 SoftStrider Treadmill
Healthrider 500i. The screen lights up with no belt, fan, or key pad response. I manually started the belt then it wouldn't stop or change speed.
adjust the Reed Swith see the diagram:RESET, clean, and tight cable connector.
2) Run the software calibration for easy diagnostic, troubleshooting, and fix it.
God bless you
Aug 28, 2012 | HEALTHRIDER Pro H500i Exercise Workout...
Where can i get a new key for my treadmill
go to www. fitnessrepairparts.com or www. doctortreadmill.com
www. treadmillpartszone.com
God bless you
Jun 13, 2012 | HEALTHRIDER R60 SoftStrider Treadmill
Healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Jan 24, 2012 | HEALTHRIDER Exercise & Fitness
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
I have a Healthrider Softstrider s300i treadmill and it will shut off with no warning after 35 min or so. I take out the safety key, reinsert it after a few min and it will go again.
see block diagram
Jun 27, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
My son folded my healthrider s300i while it was in an incline position now the incline doesnt work is there a reset to fix this?
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Jun 23, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
I have a HealthRider S300i treadmill, but unfortunately, I don't have the included allen wrench. So far I've been unable to figure out what size allen wrench I need. Any idea?
Feb 09, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
Belt is not the correct speed when you put ypur weight on it...slows down.have to put on 5 to get a 3 walk?
If the walking belt is overtightened, treadmill performance may decrease and the walking belt may become damaged. Remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts counterclockwise, 1/4 of a turn. When the walking belt is properly tightened, you should be able to lift each edge of the walking belt 3 to 4 in. (8 to 10 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened. . If the walking belt still slows then lubricate running deck the lube may be purchased from iconfitness.com
May 04, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
HEALTHRIDER R60 SoftStrider Treadmill Logo
16 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
