Question about LG MU-50PX10C 50 in. Plasma HDTV
Changing Blue splash along bottom and side
I purchased an LG LCD 55" Television and I have this Blue Haze Splash that runs along the bottom and right side of the screen. It changes shape and size the longer the TV stays on. Guy I purchased it from has moved out of state. Any suggestions or explanations?
  • 346 Answers
change the power regulator
Posted on Nov 01, 2007
  • 472 Answers
SOURCE: LG RZ-26LZ50 LCD Television-Solid Black line down the right had side of the screen
It's the driver tabs that operate that section of the panel. To have them repaired/replaced can be very expensive and is normally just replaced completely as a whole panel (at least while under warranty). If it is out of warranty, then get a few quotes over the phone. This will help dramatically when you explain to your wife that you are about ot go shopping to buy a new TV.
I find things like "Have I told you how good you look today" help when this process is taking place.
Sorry for the bad news.
Posted on Apr 12, 2008
SOURCE: LG 32LC2R screen goes black after 2 sec.
My LG 32lc7d 32 inch TV is 9 months old (December 2007 to September 2008) and now the screen goes black with sound and the channels will change I can hear them. Also when the TV is fine if I touch the remote it freezes the picture, so turn it off and on witch does not respond to the remote for five seconds, turn it on again & it works for 2 to 3 hours then same problem. LG claim its a software problem, well I got link to the firmware update down load to my memory stick and stuck it in the usb port on the back of the TV, software update fine no problem, TV reset all my preference are lost no problem I can set it how I like it ,but now worst things are happening the screen goes black after 15 to 20 minutes and no sound now ,so the firmware did not work but cased more problems and less viewing time .NNNOOO more LG product for me in life again .
I bought the TV for $1000 us and the DVD up converting player for $110 + sound system
So I could 1 remote to make life easer for me, but life is better for LG now since they have my money and all I have are their problems.
We should come together and attack LG about this problem or boycott them and their products for good, hundreds of thousands of people have this problem and nothing.
What’s the sense of a warranty if there no fix for your problems and you can’t get your money back. I have bought so many LG products and now no fix. There are millions of people who don’t have a $1000 us in there bank account..
I now feel like I was held at gun point and robbed by millionaire.
Posted on Sep 25, 2008
On a LX2R to remove the green bar at the bottom or the blue bars on ths side using the sky HD box go to menu and the pip menu at the bottom of the list, access input and make sure the HDMI input is on DTV and NOT PC.
Posted on Aug 07, 2010
  • 608 Answers
SOURCE: my lg lcd tv keeps flashing with the stand by
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found at but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Posted on Dec 16, 2010
Testimonial: "Thanks your help has been very much appreciated..."
  • 506 Answers
its no big problem.I implore you visit the user's manual to see how to zoom and undo it. Get back if you encounter further problems.
Posted on Jul 15, 2011
0 characters
1 Points
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes.
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Hello, I have a 40" Samsung LCD flatscreen. My television has a 2.5" diameter black spot on the far left side about 4" from the bottom of the screen, Also we have a dark transparent band across the bottom...
Sorry Sir but your LCD TV got wet... it can be splash with too much water, an animal urinate on the panel, etc....
this kind of black spot is caused when the LCD Panel Terminals got wet, this terminals are located at the lower side of the LCD Panel.
Sep 15, 2010 | Flat Panel Televisions
Blue haze on sharp aquos tv can thius be repaired?
if you have haze or dark pic on one side usually bad lcd panel. i called recently on a sharp 47' panel cost was 2300.00
Jun 01, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
We have a blue haze on our screen. We replaced the Lamp light and it still is visible. It is on the right side corners only
This problems is not the lamp,ur lamp is good.U still have the old lamp saved it.The lamp is good.Ur convergence is dead.That why u have a blue haze.The 2 convergence ICS must replaced to solved this problems.U know how to solders?Tries Websites Tv repair, to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 23, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Screen appears blue
Try Moving The Speaker You Have There Away From It?
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Blue haze on my plasma screen
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
Aug 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
No Picture at all no matter what source. Audio is okay. Any suggestions?
Do you get the blue splash screen that says "AKAI" when you turn it on?
Aug 01, 2008 | Akai LCT3285TA 32 in. LCD Television
The driver boards on that side of the set need to be replaced, about $400 for parts.
Jul 02, 2008 | Samsung HP-T4254 42 in. Plasma Television
Blue Haze
yeah I have the blue haze also whats up?
May 20, 2008 | Hitachi 50V720 Television
Olevia 32" Video question
if unit is still under warranty, utilize it. otherwise your y-sus bd is failing. the problem will get worse. hope this helps.
Feb 18, 2008 | Olevia LT32HVM 32 in. LCD Television
LG MU-50PX10C 50 in. Plasma HDTV Logo
Top LG Flat Panel Televisions Experts
Are you a LG Flat Panel Television Expert? Answer questions, earn points and help others
