Question about Grilling
Masterbuilt smoker 20072612
After setting time, heating light comes on for 2 or 3 seconds and then goes off
SOURCE: Element won't heat on Masterbuilt smoker
I called Masterbuilt and they said they no longer sell the elements. you have to buy the cabinet @ $189 for the 40" model. I decided to pull my element and see if i could find one that would work by going to an appliance repair parts store.
When i pulled the element, i found that the terminal that plugs into the element was burned/melted in two. i replaced the terminal end, pluygged it in and tis working fine.
to remove the element, you need to remove the element cover/chip loading chute first. its easy, 2 sheet metal screws and 2 nuts and 2 machine screws. one of the nuts/machine screws is a little hard to get back on when you reassemble but it can be done. after the cover is removed, you will see 3 screws where the element goes through the back wall. only removed the left and right ones. do not loolsen or remove thecenter one. after you remove the 2 screws, you can coax a small amount of the wire leads out into the open and you can inspect them to see if they are broken.
if the problem is truly a bad element, you will have to find an element somewhere. i cant help with this except to say that Masterbuilt customer service says they are negotiating with their supplier to see if they can sell the elements seperatly. they hope to have that resolved by summer.
hope this helps.
D Smith
Posted on Dec 09, 2008
  • 72 Answers
SOURCE: MASTERBUILT GAS SMOKER
Here is the link for the maunel online in pdf format
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
the main website says individual parts will be availible for sale soon, main website is
http://www.masterbuilt.com/index.html
hope this helps
Posted on Nov 09, 2008
SOURCE: Masterbuilt Smoker Model 20070108 Digitial Controller not working. Worked the first time, then no power. I hear a beep when I plug it in, but no display.
I had the same problem this morning. I seasoned it two days agao with an outside temp. of 50. This morning it was 8 degrees and when I pluged it in there was no readout. I removed the digital unit from the top and heated it with a hair drier and it worked when I reinstalled it. I think it had some moisture in it although the unit has been covered the whole time. I am going to call Masterbuilt tomarrow and see what their answer is to this problem.
Posted on Jan 25, 2009
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
heatman101
  • 43501 Answers
SOURCE: can you buy a replacement heating element
Here is a pdf of the smoker book and on page 4 there is a parts list with the cust. service number to order replacement parts...there is an element kit listed there, that is what you need.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
heatman101
Posted on Jul 25, 2010
Masterbuilt 20072612 ERR1 error code
ERR1 MEANS YOU NEED A NEW BODY KIT. PER MASTERBUILT, THE SMOKER IS DEAD AND NEEDS A FULL BODY KIT (BASICALLY THE ENTIRE UNIT)
Apr 18, 2014 | Masterbuilt 20070106 Electric Smoker
My masterbuilt smoker is about two years old and worked well up to last weekend when the heating element did not warm up. The digital control indicated that there was power to it,it appeared to be...
the element has given out most likely, you can test the element with a meter by checking for resistance. If there is no resistance it is bad.
Aug 14, 2010 | Masterbuilt Grilling
I purchased a masterbuilt smoker in Jan/2010 Model E 20070910. First time I used it had no problem with generating smoke but ever since I can not generate smoke I've tried pellets & even Hickory...
Try this...
Mike in Alaska
PSU313@yahoo.com
Jun 17, 2010 | Masterbuilt 20070106 Electric Smoker
Heating Element Failure
Mike in Alaska
PSU313@yahoo.com
Apr 03, 2010 | Masterbuilt 20070106 Electric Smoker
Used the masterbuilt smoker only 5 times???
Mike in Alaska
PSU313@yahoo.com
Jun 20, 2009 | Masterbuilt 20070106 Electric Smoker
The Control lights up and can set time / Temp but it doesn't heat
I get mine from Grillparts.com....I believe they are here in Floriyda.You might search around in the Yellow Pages for somebody close to you
Mar 23, 2009 | Masterbuilt 20070206 Smoker
Grilling Logo
2,152 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
