Question about Motorola Mobility RAZR V3c Cellular Phone
Display name How do I change the display batter on my Razr. It says At&T. I want it to say something else. I can't find the option to change it in the settings.
  • matt muench Aug 07, 2007
    So there is no way to change it???
  • 28 Answers
If the At&T banner is in the upper left of the display, it is read from the SIM card.
Posted on Aug 07, 2007
SOURCE:
How do you change the display names on the Avaya 5420.
hi robert.
see if this helps you,if not go to the link and the bottom.
How to change the display name in Avaya phone? Press the Select soft key or the OK button or the right arrow key. Use the up and down arrow keys to scroll the display to the option Display Name. Press the Change soft key to change the setting or use the left or right arrow keys. Display your extension number and the date and time on the phone when it is idle.
Display Name - Avaya
marketingtools.avaya.com/knowledgebase/user/ipoffice/.../1408/display_name.htm Search for: How to change the display name in Avaya phone?
How do you change the display names on the Avaya 5420 Google Search
Nov 03, 2017 | Avaya Lands Phones
How to Change Display Name
There is no option for it on your extension because your "class of service" is not set for it. Probably the only extension set for name change is 301 if the default configuration was not changed.
Mar 25, 2017 | NEC DSX 22 Corded Phone
Display name not mine, how do i change it?
Here's a link to the individual steps:
http://www.telephonesystemsdirect.com/necdsx/nec-dsx-knowledge-base/changing-the-name-on-a-nec-dsx-22b-display-tel/
Dec 16, 2013 | NEC DSX 22 Corded Phone
Display ic motherboard
A> Check you Power all connection proper connected.
B> Check you SMPS power proper working or not.
C> If direct display not coming then sec option is external display card connect in mother board and check display come or not. if display come then you internal display cheap damage. If both option used or display no then you mother board problem.
D> Check you RAM, section if RAM problem then display no.
E> And finally one time mother board bios batter disconnect and few sec wait and re-connect bios batter. Remember batter disconnect before all power cut.
Thanks...
Aug 26, 2013 | Dell OptiPlex Computers & Internet
Problem with Display name in mesenger chat room and call option
Ok. I was the original poster of this problem, I have now found a way to solve this and will share the solution.
http://p1.pf.re4.yahoo.com/PUT_YOUR_ID_HERE and log in you can now edit your Nick Name.
About your sound problem, try to check your sound driver if it is ok outside of yahoo and if its not go to http://www.freecreed.com to get a codec.
Nov 23, 2008 | Yahoo Messenger
Want to change external display
Yes I do... first question is your phone under warranty.. because if it is you void the warranty do this..
second.. do you have a USB cable? and software? You will need something like P2K Commander... set it up with MSU and you want to go to the a:/ mobile folder you will see the verizon.gif file in there DO NOT DELET that file.. you are going to replace it.. Find a file that you want to you make sure the size is 96x80.. Change its name to verizon.gif and replace it in that directory.Restart the phone and VOILA! I have an evil Smiley on my outside LCD!
Mar 24, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Razr display goes dark
yes i think that in the phone you go to option menu in menu settings in setting displays is the option there you have the option to either turn off the display or choose the interval like 1 minute or 2 minute.
Jan 11, 2008 | Motorola Mobility RAZR V3
Razr external display
Has the phone ever displayed this information?
First try Enabling Caller ID, if that doesn't work then Shut Down the phone, remove the battery, then replace the batter and try again.
Dec 28, 2007 | Motorola Mobility RAZR V3
No date display
yep i have the same problem too. no date display. it displays the date on the outer screen when i flip the phone shut. but not on the main screen when it is open.
Jun 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
