Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Oil leak causes smoke & accumulation of oil at base of my lawn boy 10685 pushmower
SOURCE: 2 cycle oil to gas ratio for Lawn Boy mover Model 10324
32 parts gasoline : 1 part oil
Posted on May 06, 2009
  • 89 Answers
SOURCE: what locks in the left and right torsion springs
the proper set up on thre bar which hols thr springs is plate lock handle part 107-3946 then the right hand torsion spring 108-0953,make sure the spring hooks over the plate lock, then left hand torsion spring then bar slides through left hand hole and lever release 40-1823-03 attaches to end of bar with a set screw
Posted on Nov 04, 2009
SOURCE: The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Posted on Jul 01, 2010
HansPP
  • 2510 Answers
SOURCE: I have a Lawn Boy
Remove the spark plug and try pulling the starter again. You may have a fuel leakage into the cylinder and it has caused a hydraulic lock. Check/change the needle and seat in the carb as this leaking is the usual cause if this type of problem. Good luck and please rate this solution.
Posted on May 22, 2011
GodBlessU
  • 3513 Answers
SOURCE: i changed oil, blade, spark
Hi
Make sure the blade and shaft can easily be moved by hand. First, remove the spark plug wire from the plug. Reach under the mower and see if the blade will turn or if something is stuck between the blade and the mower. Also remember that you have to hold the safety bar when you are starting the mower or the engine won't turn. It is possible that the cable from the safety bar to the engine brake has come loose. Follow the cable from the safety bar to the engine and make sure it is working.Also check whether the line from the gas tank to the engine is crimped?
Also check this link to troubleshoot your problem:-
http://www.ehow.com/how_7363405_troubleshooting-push-mowers.html
Posted on Aug 04, 2011
I have a Lawn Boy 10685. It sat for about 4 years. It would not start. I replaced the spark plug and added gas. It started right up, but the engine is high revving? what would cause this? How do I fix
Sounds like the return spring on the air vane governor is stretched. Take the shroud off and look for the paddle shaped piece of plastic next to the flywheel. There should be no slack in the attached spring. You can shorten the spring if needed with a pair of needle nose pliers.
Sep 21, 2014 | Garden
Oil mixture for 1985f series 2 cycle lawn-boy mower
Contact your dealer ! but 32:1 sounds correct. 8 ounces of Lawnboy oil to two gallons of gasoline ....is 32:1, 8 ounces of oil to one gallon of fuel is 16:1 for the real old lawnboys,
When Toro bought out OMC,and started using Tecumseh mowers,the ratio changed in the late 80's or early nineties ! IIRC :o)
Jun 11, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
What Oil so I Need for a Toro lawn mover 6.75 HP ?
I think you are talking about a Toro pushmower with a 6.75 Briggs motor on it. If so; it is a four stroke motor and requires 10w-30 motor oil.
If it has a dipstick then its a 4-stroke. If there is no way to add oil to the crankcase and no way to check the oil level then its a 2-stroke ( ie. lawn boy and some really old snapper pushmowers)
Oct 06, 2012 | Garden
Lawn Boy pushmower blew out lot of whitish-blue smoke after starting (has not run in 110 days). Checked oil level, was to high, so removed some oil, after thar ran fine but after 10 minutes, same...
Hi, change the oil and your problem will be solved. Basically it was over full because fuel has by-passed the carby needle and leaked into the sump while its been sitting idle. Regards Phil.
Aug 14, 2011 | Garden
My Troy Built Self propelled lawn mower has a oil leak which results in white smoke coming from it. What is causing it? I had it for 3 months.
Hi smithjazzy8...
Check your oil level, it sounds like it has got too much oil in the crankcase.
The oil level should be to the last two threads on the fill plug threads of the engine.
This is the main cause of white smoke coming from the exaust of the engine.
Free Answer...Please take time to rate me.
May 30, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
I have a Lawn Boy 10685. Changed the blade and went to start the mower and the pull cord will not pull. I tried spinning the blade by hand with no luck. I took the starter apart and it spins fine. I check...
May 22, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn boy 2 cycle that smokes
Check the air breather. Make sure it is clean.
If it is clean, you will probably need to replace the diaphragm. A bad diaphragm will cause black smoke and also cause the mower to run erratically.
Jim
Jun 21, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
14 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
