Question about Garden
Briggs and Stratton 475 series pressure washer
Editor925
  • 285 Answers
SOURCE: Pressure washer with no pressure
Are you priming the water lines before you switch on the power?
i.e. with power OFF, hook up hose and turn hose on (doesn't need to have much hose pressure), then take your spray gun or attachment and pull the trigger and allow water to flow through the system (at hose pressure obviously). You might need to gravity feed it if its not flowing through...
But you will generally only get pressure once all the air is removed from the lines and the pump is pushing water only... Once you have water flow and lines are primed, switch on pump and see if that solves it.
Posted on Mar 17, 2009
sr6248
  • 66 Answers
SOURCE: Briggs and Stratton pressure washer will not spray
The nozzle on the end of the spray wand has a very small hole in it that can be easily clogged by any sort of debris that comes through the water supply.If the nozzle can be removed, just take a pin & clear the hole from the outside & rinse it off. If the nozzle can't be removed, then take the wand apart at the connector in the middle and do the same thing.
Posted on Jan 30, 2010
SOURCE: 2200 psi husky briggs and stratton pressure washer
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
SOURCE: how to change oil in a pressure washer
From the manual CleanShot 2050 Briggs and Stratton
Change Pump Oil
1. Drain engine oil and fuel from pressure washer
2. Use an 8 mm allen wrench to remove black pump oil cap between high pressure outlet and garden hose inlet.
3. Tiltl pressure washer to drain oil into an approved container until it drips slowly from pump.
4.Tilt pressure washer in opposite direction and empty premeasured pump oil bottle into same opening (a small funnel may be helpful) [THIS IS WHAT THE MANUAL SAYS-NOT CLEARLY WRITTEN IN MY OPINION OR WRITTEN BY SOMEONE FOR WHOM ENGLISH IS A SECOND LANGUAGE]
5. Install black pump oil cap and tighten firmly.
6. Set pressure washer in upright position. Add fuel and engine oil.
From the engine manual use synthetic 5w-30, 10w-30 from -20 degrees F to temperature of 100 degrees F.
Change oil after 5 hours of operation initially. Before tipping to drain oil, remove fuel from fuel tank by running until tank is empty. Remove oil cap and dipstick and tip engine. Keep spark plug side up. Or remove drain plug from the bottom of pressure washer with a ratchet and square extension and drain oil from bottom. (fuel does not have to be removed)
Posted on Apr 22, 2010
SOURCE: I have a Briggs & Stratton pressure washer,
If #1 doesn't work, the ports in your carb could be clogged. I just dealt with this problem this weekend. This is a relatively easy fix. Locate your carburetor and find the aluminum bowl underneath. On the bottom of the bowl, you'll find a bolt. Loosen the bolt (gasoline will come out because the bowl is a reservoir for gas, but please make sure you've turned the gas supply off) and remove the bolt and the bowl. Clean any debris out of the bowl. The ports are holes in the bolt you removed. Make sure that air can pass through these holes (I blow through them, but I don't mind the taste of gas too much. Probably NOT healthy. You can use thin wire, carb cleaner, etc..) Reassemble and your motor may start, if this was the problem. Make sure that the bowl seats properly and that you are careful screwing in the bolt, lest you cross-thread it. Hope that helps.
Posted on Apr 29, 2010
Need a repair manual for briggs and stratton 31p707 18.5 engine
i need to see the manual for a o turn john dear mower on corborator & linkage
May 27, 2012 | Briggs Stratton 020273 Elite Series...
How do I winterize a Briggs and Stratton pressure washer
Change engine oil, add fresh stabilized fuel,start and run to circulate new fuel. Use a section of hose and pump som RV antifreeze (the pink stuff) through your pump and hose if you are leaving your hose and wand hooked up.
Hope this helped
Nov 03, 2010 | Briggs Stratton 020273 Elite Series...
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
What kind of oil do I use in my 675 series engine
4 stroke synthetic is most likely what you'd want to run if it's a new unit to yourself. Otherwise any 4 stroke motor oil is fine, you can find it at any retailer that sells small engine machinery.
Apr 21, 2010 | Briggs & Stratton Gas Pressure Washer...
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
